Old 27th December 2023, 06:21 PM
The issue I have is I don't know where this is located or what it looks like on a 2011 4.2tdi Q7! Is it a relay (in the relay box under the bonnet) or an actual module maybe under the ECU? Any help would be appreciated.
According to ETKA, it is indeed a relay, where you stated. The part number depends on engine code, which are as follows for the 4.2tdi:
CCFA - Part# 038907281B or 04L907282B - stamped 457
CCFC - Part# 4L1907282 or 4L1907282A - stamped 652
I would double check which you have before proceeding (as ETKA can sometimes be wrong).
