Old 16th May 2022, 09:01 AM
The following image should help in identifying all the relevant fasteners required. Based on the image, these are the associated part numbers, and how many you require per side. Note that these totals are for both parts of the wheel arch liner on either side of the car, and not just the front part. I've also attached images of what the part numbers look like in reality.
And yes, part numbers 12 and 14 are the same. Must be an Audi thing!
#10 - 171201969 - Hexagon collar nut (8 per side)
#12 - N90250001 - oval head panel screw (2 per side)
#14 - N90250001 - oval head panel screw (1 per side)
#15 - 4D0807300 - Spreader rivet (4 per side)
#16 - 443821699 - Clip (2 per side)
#17 - 811807577C - insert nut (1 per side)
Name:	A8 D2 Wheel Arch Liner.png
ID:	28469   Click image for larger version
Name:	PN 171201969.jpg
ID:	28470   Click image for larger version
Name:	PN N90250001.jpg
ID:	28471   Click image for larger version
Name:	PN 4D0807300.jpg
ID:	28472   Click image for larger version
Name:	PN 443821699.jpg
ID:	28473   Click image for larger version
Name:	PN 811807577C.jpg
