Old 14th May 2024, 10:47 AM
I might look at swapping the sounders over to see if that's the problem on the 25yo original.
Well all that I've proved is that I have two faulty alarm sirens with different electrical problems!
I've tried both units, with and without batteries and with both speakers in turn.
The original talks happily to the car and enjoys new batteries when fitted, but won't drive either speaker (they have the same connection).
The later one loses communication with the car triggering the alarm. It works with either speaker. Without batteries it still sounds but throws battery voltage errors of course.
So if anyone coming to the meet in June happens to have an old spare alarm siren kicking around I'll happily relieve you of it and see what I find inside.
(Original 8L0 951 605 or later 8L0 951 605A)
Old 17th May 2024, 03:05 PM
Well I've taken a punt on an Original 8L0 951 605 I found on eBay (commercial breaker, not our sponsor!) and made a cheeky offer that was accepted on the basis that it will work but the batteries will need replacing.
If it actually works I will indeed replace the batteries, if not it will go back for a refund.
And on a related note I've bought a nearside dimming mirror glass from "Spanker".
Old 21st May 2024, 01:55 PM
Well it didn't work at all - No Communication according to VCDS.
To be fair, the seller refunded immediately, didn't ask for it to be returned (extra pointless cost I guess).
So I cut it open to see what I would find, though I could guess! Yuck!
Found an 8L0 951 605A going cheap so might try that.
Old 21st May 2024, 04:09 PM
And I thought the one I took out of mine years ago was bad.
Old 22nd May 2024, 01:07 PM
That's nothing like as rotted as the one I received - lots of the smaller components had just disappeared, corroded away!
Meanwhile I've put back the original 8L0 951 605, with good batteries, to see what happens. No errors thrown up but equally no sounds either. Waiting for the next genuine but old 8L0 951 605A to arrive.
