Old 4th October 2022, 07:15 AM
roberto's Avatar
roberto roberto is offline
Default Wanted Q7 3.0tdi 2014-
as above please
Old 27th October 2022, 11:18 PM
roberto's Avatar
Default found one
got a beauty with great spec 2014
very pleased so far
Old 28th October 2022, 08:30 AM
pete-p's Avatar
pete-p pete-p is offline
Another Q7 owner! Welcome to the club
Very practical cars although I need to find an electrical drain on mine. Probably the door handles.
Cars...
Old 3rd November 2022, 03:12 AM
roberto's Avatar
Default cheers
how does a door handle drain the battery ?
Old 3rd November 2022, 11:50 AM
Same as on the A8 (and probably other models as well). The modules controlling the handles don't go to sleep and result in a small drain on the battery.
Old 3rd November 2022, 08:00 PM
pete-p's Avatar
I'm definitely seeing a fault code. Depends if you have the convenience key.
Just finished another long drive from Weston-super-Mare to St. David's and then across the water to Carlow. Five people and every space full of luggage plus a full roof box. Lovely drive in the Q7.
Cars...
Old 4th November 2022, 02:31 AM
roberto's Avatar
Default aaah righto guys
i do have keyless entry and start same as the A8
ive also noticed 3 door handles work perfect and one doesnt
the button is stuck in and doesnt give a Micro switch type click
is it possible to change this tiny button?
and my battery seems fine atm
Old 4th November 2022, 10:47 AM
In theory yes, but in practice it appears to be a PITA to do. Much easier to get a new door handle. Underneath the button is an even smaller surface mount switch, around 5mm square, so you'd first have to remove the handle from the car, then dismantle the handle to get at both sides of the PCB holding the switch, replace it with a new switch (assuming you can find an exact match on the likes of eBay) and then put it all back together again. I did come across a video of someone who attempted to do it but gave up. It's worth watching it just to see the switch that needs replaced:
https://www.youtube.com/watch?v=9d8S5LeWp9w
Old 5th November 2022, 07:52 AM
roberto's Avatar
doo-able i suppose
question please
are all 4 door handles the same ?
Old 5th November 2022, 09:13 AM
Drivers door has part number 4E2837206G (RHD) and the other three have part number 4E0839205G.
