Old 10th May 2023, 11:24 AM
monkeyboyuk monkeyboyuk is offline
Default WANTED - bulb holder for pf d2 indicator
Hi everyone, as some of you may have seen from my previous post about my n/s indicator saga i'm after a bulb holder which has been ripped off when the lamp unit fell out after poor fitting by garage.
does anyone have one lying around? or know if there are any other equivalent items that will directly replace this part which is surprise surprise nla.....
2014 D4, FL 3.0tdi, phantom black, sport exec lwb
2002 D2 S8, Aqua Blue Pearl, original bar FE alloys and miltek
1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting….
1990 2.3 20v 7a Coupe Quattro
**SOLD** 1996 2.6 v6 cabriolet, Isis red metallic
**DEAD ** 2009 D3, 3.0tdi sport, black
Had a few Audis over the years, mostly early stuff, newest was a D3 prior to my D4, nothing much kept me smitten with other marques so I floated about a bit from one thing to another until that four ring lure caught hold
Old 10th May 2023, 09:32 PM
Ronin Ronin is offline
do you have a part number? that's the best way to search.
Old 10th May 2023, 10:59 PM
Got it in office at work…… will post it tomorrow and let know if I track anything down
Old 11th May 2023, 11:14 AM
Is it possible to clarify exactly what part you need by showing us the same part on the other indicator? The reason for asking is that in the following thread you posted a photo of the indicator after the outer half fell off, and the photo shows the bulb holder intact:
http://forum.a8parts.co.uk/showpost....5&postcount=16
Looking in ETKA (#7 in the attached image), the part number for the bulb holder is 3B0953123B and there doesn't appear to be any other parts to it.
If this is indeed the correct part you require, your best bet based on the ridiculous prices on eBay for them (both new and used) is a visit to a scrapyard, as they were used in various VAG vehicles from '91 to '03 (and some Fords of the same era).
Name:	A8 D2 PF Indicator.png
Old 11th May 2023, 08:40 PM
Yep that’s the part I need and part number I have, it’s actually incomplete, not sure if that previous pic shows it accurately or if it’s fallen off since then…. I’d assumed it was ripped off at same time. There’s no bit to physically insert the bulb into or to affix to back of lamp unit
Old 12th May 2023, 09:52 AM
Thanks. Just did another search on eBay and came across the following listing. Not as bad as the other £30-£40 ones, this one is £16 for 3. It has the same part number, but I'd would compare the photos with the one you still have to be absolutely sure they are correct:
https://www.ebay.co.uk/itm/173728622116
Old 14th May 2023, 07:18 PM
Cheers for that. I’ll have look when I’m back home. Nipped up to Scotland for a jaunt with my new daily whip……
Although I’d had a quick search on autodoc and suggests that part numbers not for my d2
Old 15th May 2023, 08:55 AM
3B0953123B is definitely for the D2 through it's entire lifespan. The 3A0953124 number is just the equivalent on Seats and VWs (and Fords).
