Washer fluid pump
So replaced the washer pump from on off eBay but does not work still
There is no noise from the pump so is it just a cheap eBay version that does not work? Is there a fuse anywhere for this washer pump or rely? The wipers work for sure just not the washers Headlight washers work fine I’m assuming I should hear the pump working- I have no leaks as I replaced the grommets too I’ve tried cleaning the nozzles too I’m going with another faulty pump as no noise Thanks
2002 Audi A8 D2 3.7 Quattro AquaBlue |
there are 2 pumps.
Which one did you replace? |
The black one with the two grommets
Absolutely. I got mine from eBay and it worked fine. Sounds like it's a dud. Can you check the connection and see if it's getting 12v when you activate the washer from inside?
Have just put it back together
I have ordered an original used one- when that comes I will try check connection but not sure I have a voltmeter - just basic tools
On the other note at least I stopped the leak with new grommets
