Old 28th October 2019, 04:43 PM
homer simpson's Avatar
Default My (strange) suspension problem
I posted this in my other thread but better to start a new one here. I have read virtually every thread on suspension faults but mine seems different as it doesn't appear to have a leak. When parked, it drops the NSF to the deck. No hissing and strut has been checked for a leak. The compressor pumps out 14.5 bar. There are no fault codes with VCDS. When I start the car, it raises the NSF to normal level and the car drives as it should. Headlamps are also at the correct level and the NSF level sensor is fine.
What else can I check? It's almost as if the car is telling the NSF to drop when parked (over time). I guess the valve block is left to check (is this under the inner wheel arch?) but I would expect to (a) hear this and (b) expect faults along with it struggling to rise.
Old 28th October 2019, 04:51 PM
Yes, it's behind the rear section of the arch liner, up against the bulkhead.
Old 28th October 2019, 05:02 PM
Mine was like this it was the strut leaking but there were no bubbles externally or hiss to be heard. The car would prediocally top it up from the pressure in the reservoir for about 8 hours.
I replaced the airbag and aluminium housing, the airbag was in perfect condition, I think the leak was at the internal o-rings
I replaced the valve block first to no avail that is easy enough, just need to be scrupilously clean when fitting the connections.
Old 28th October 2019, 06:06 PM
Thank you
Did you just chance it by replacing the airbag? Any fault codes?
Old 28th October 2019, 06:47 PM
Yes I chanced it. If I had my time again, I would perhaps get a knock-off Chinese new one for around £200 or keep my eye open for a decent-looking used one, such as from a 2008 or 2009, but sadly they go for quite a lot of money just to take a punt on a 10+year old used wear item.
The same goes for the knock-offs they are a risk too - how do we know the variable damping is all the same as OE specs?
Rebuilding mine was a pain to dismantle and when it was opened I found the damper had been leaking damper oil but continued with the rebuild as I already had the part and the air strut was already in bits. There is also a slight knocking on the front offside that has persisted for years which I think is the damper as I have replaced everything else at least once, so I might bite the bullet one day and go with one of the first two options.
Old 28th October 2019, 08:05 PM
I've been looking at these that were posted on the forum. They do a full strut too
https://aerosus.co.uk/audi/a8-d3/aud...pring-bag.html
Old 1st November 2019, 07:58 PM
Y
I've seen the videos ad it doesn't look too bad...Did you remove the upper arms or undo the big nut and remove it that way? Still deciding whether to but the bag or complete strut.
