Old 12th April 2024, 08:00 AM
Default Clock/Radio clock on the blink
Got in the S8 this morning just before 9am and the clock/radio clock showed 15:13 on 16 October 2024! The radio clock signal indicator was on and I can adjust the hour on the clock (on the dash and the menu) but nothing else.
Anyone got any idea as to what has happened?
Old 12th April 2024, 10:24 AM
You're just ahead of your time Jim, as usual
Old 14th April 2024, 12:33 PM
Anyone got any more helpful suggestions?
Old 15th April 2024, 09:00 AM
Reading through the 'Retrofitting radio controlled clock' thread, can I assume you've tried the clock sync procedures Sergey and AdrainE suggested:
Sergey's full version - involves pulling the fuse
Adrian's shorter version
I can't find anything else online about errors in radio controlled clocks of any sort where the month is months out, or even the time being hours out.
I rarely see the mast icon on mine, and it sits outside 24/7. Saw it initially, but at some point it disappeared, and never followed up on it. I might try it the next time I'm at my nephews, if I remember.
Old 16th April 2024, 05:46 AM
Thanks Sean. I’ll give that a go
Old 18th April 2024, 09:36 AM
Well this is strange! I’ve done none of the reset stuff and only tried to change the time. After a couple of days, the date was correct again but the time was a long way out. Then the minutes and seconds were correct, but the hour was way off and kept resetting incorrectly after I changed it. Then, this morning, it’s all OK; even the hour is correct for UK time without having to change it from CET.
Go figure!
