Old 16th November 2020, 02:07 PM
Default Bonnet struts
I think my bonnet struts have come to the end of their life as the bonnet often shuts itself when I leave it open.
Are there any recommended makes of replacement strut, or makes to avoid (Chinese ones will be avoided, of course!)?
Old 16th November 2020, 04:59 PM
The brand names I came across for original suppliers are Stabilus, Lesjofors (two dots above the first 'o'), Triscan, Quinton Hazell, Delphi and Febi Bilstein, and I've only heard of the last two.
Lots available on eBay from the likes of Meyle and Magneti Marelli as well as 'other' brands, but MJs opinion is probably the best.
Part number by the way is 4D0823359F.
UPDATE: Forgot to add the specs for them if looking at other manufacturers for them. Length - 530mm, Housing diameter - 18mm, Piston rod diameter - 8mm, Eject force - 245N, Stroke - 215mm
Old 16th November 2020, 05:05 PM
Thanks for the data, Sean. Very helpful.
Old 16th November 2020, 09:22 PM
Ronin Ronin is offline
I think phaeton chrome struts fit the A89 D2 just like the rear boot struts
Old 17th November 2020, 09:45 AM
johnny_quattro's Avatar
The original struts that failed to lift the bonnet on my car were made by a Belgian company called HINSCHA with the '4027CV 0245N' code printed on the side of the strut casing. I did a bit of searching around on 'tinterweb' and eventually plumped for a set of front struts called Nitro Lift for my car from SGS Engineering. Work really well, easy to fit. I think they're up north somewhere, Derby (I just checked). I've attached an image of the measurements in PNG format.
Last edited by johnny_quattro; 17th November 2020 at 09:58 AM. Reason: Added PNG image
Old 17th November 2020, 10:03 AM
Ha ha! Only a Londoner could call Derby “up north somewhere”
But thanks for the recommendation. I think my boot struts were from SGS, so I’ll check them out.
