Old 22nd February 2023, 04:54 PM
Julian Thompson Julian Thompson is offline
Default How to check if an A8 has servotronic, plus, where is the relay?
A8 4.2 tdi lwb 2008 - I assumed it would have servotronic. Checked the relays under the passengers feet and the ones behind the fuse box up under the dashboard. No sign of relay 605 anywhere. On vcds I just get “module not responding” - seems to me it doesn’t have servotronic, but I thought they all did after the .3 revision in 08?
Thanks in advance.
Old 22nd February 2023, 05:15 PM
Do you still have the build sticker in the spare wheel well? If so, check for QZ0 (QZ* is power steering related) and 1N3 (1N* is also power steering related).
EDIT: According to the '06 brochure, all A8s had Servotronic.
Old 22nd February 2023, 05:46 PM
Fantastic thanks I will take a look this evening and report back. Assuming it does have it where the heck is the relay?
Old 22nd February 2023, 06:40 PM
From what I can find, there doesn't appear to be a relay. Check the following PDF from page 22. The N119 valve is controlled from module J520 (vehicle electrical system), which takes input from module J104 (ABS).
51-SSP 285 Running Gear in the Audi A8.pdfhttp://forum.a8parts.co.uk/attachmen...1&d=1420368035
Old 22nd February 2023, 08:20 PM
Here is the sticker. Can’t find either code.
Oddly when I rang the dealer to buy the servotronic relay he gave me part number 4D0907307 - and a quick search shows that on the Audi A6 of similar year some people don’t like the feeling of the extra assistance so have either removed the relay or rigged up a switch to knock it out when they want.
I have another D3 that’s a 2006 car which I’m almost sure doesn’t have servotronic and the steering on the 2008 feels the same weight wise, hence me thinking the relay could be worth changing.
Old 22nd February 2023, 08:28 PM
Looking at that really cool document you linked to I think that they’re handling the components a level closer to the action than the relays and fuses, hence no mention of them. I expect it will need the relay though to actually power the system once logic decisions are made by the processors.
Old 23rd February 2023, 11:46 AM
Assuming that the brochure is correct and all A8s came with Servotronic, maybe that's why it's not listed on the build sticker - I never thought about that.
Strange that they gave you that part number as it's for the PF D2.
