Old 2nd March 2023, 08:25 PM
Julian Thompson Julian Thompson is offline
Default Ceramic brake retrofit need a bit of help please
I am investigating fitting the S8 abs unit so that I can retain the wet weather pad wipe function, but of course i need the ceramic abs unit. Can anyone help me with a part number please?
Old 3rd March 2023, 09:58 AM
Part number for the S8 is 4E0614517CB or superseded with 4E0614517CS. However, I can't find anything that designates one specifically for ceramics.
Maybe someone with ceramics can post their ABS part number.
Old 3rd March 2023, 10:12 AM
Have you checked coding options? In most models the ABS unit is coded to whatever the brake setup is.
Old 3rd March 2023, 12:33 PM
Following up on what MJ said, check out the following thread of someone doing a similar retrofit. If making coding changes, be sure to note down the current setting first:
https://forums.ross-tech.com/index.php?threads/32895/
Old 3rd March 2023, 12:46 PM
Alas that thread does imply there is a different module for it since it seems the A8 module wouldn't accept the coding for the S8. Still, at least we learned it doesn't work
Old 3rd March 2023, 01:12 PM
Just re-read that thread and also double-checked ETKA. In that thread, his unit had a BC suffix, which I initially thought was a typo, so I checked their log file and it is correct.
Checked ETKA and the 4.2 tdi (had to scan through Julian's other threads) could have had CQ, CB or CS suffixes, so worth a punt at least. Be interesting to hear the outcome.
