Part number for O ring for front differential drain plug?
Hello everyone!
I'm doing both axle seals for the front differential. According to the directions on Audipages, there is an O ring on the differential drain plug, which I'd like to replace. I've searched the parts catalog and can't find the part number, so I wonder if anyone here can help with the part number or the specs for the o ring. Ideally, I'd like to purchase this before the job, so I have everything ready. Thanks in advance for any assistance.
Audi V8 Quattro Original 5speed - Black/Black Audi S8 - Avus/Oxblood Audi S8 - Cashmere/Twist BMW 850i - Red 6speed BMW 850Csi - Red 6speed Ford Thunderbird x 3 Supercharged & 5speeds Mustang convertible Range Rover Autobiography - BRG/English Tan |
Are you referring to part #22 in the attached image? If so, the part number is 01V409057, and it comes with an o-ring.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
I think that may be the one. I pulled up the PN, and two sizes came up. Could anyone confirm which size is correct? I see M18x1.5 or M12x1.5.
There is no size given for the D2 one, but the exact same part number used in the D3 has a size of M18x1.5. Also on the D3 parts list, it lists a separate seal ring, part number N0138321, size 18x22.
Thanks for the info, steamship. I found pictures of the N0138321 seal ring, and it seems to be a metal crush washer. While the diagram you posted and other pictures I've found show a flat-ish rubber O ring. I think I'm going to order the smaller M12 bolt/seal and report back.
The attached image is from the official parts catalogue for both the D2 and D3, and it does 'appear' like its a flat-ish o-ring. However, considering where its used, the colour might be misleading. Why not order both, so long as you can return the unused one.
