Go Back   A8 Parts Forum > A8 D4 > D4 - Interior Electrics
D4 - Interior Electrics Airbags, Sensors, climate modules, instrument clusters, switches etc
Old 15th November 2022, 04:54 PM
Saff Saff is offline
Default Dashcam power supply
Hi, I'd like to fit my dashcam which has a cigar lighter plug. The socket in the front center console doesn't workat the mo so will have to sort it.
Has anyone found a better way of powering a dashcam on a D4 or suggest a small/angled 12v plug so I can perhaps use the rear console socket which has restricted access?
Thanks Steve
Old 15th November 2022, 07:11 PM
In my D4 I used a power source from within the housing behind the rear view mirror. I'm sorry but I can't remember which wires I connected it to, but I discovered them with an online search if that helps.
The housing is released by unscrewing a bolt located inside the sunglass holder.
I dismantled the dash cam's fag lighter plug and wrapped the workings with insulating tape. It fitted it easily inside the housing. Plenty of room in there.
Good luck
Nick
Old 16th November 2022, 08:35 AM
Thanks Nick
Old 16th November 2022, 09:23 AM
Check out the following thread. I've provided the link to where the OP shows how the dashcam was wired in:
https://www.audiworld.com/forums/a8-.../#post24880921
Old 16th November 2022, 07:09 PM
Thank you Steamship
Old 31st May 2024, 02:12 PM
Horrgakx Horrgakx is offline
Quick question - if the dashcam is wired to a permanent live then I assume it records all the time. That can't be good...?
[In the process of buying a 2015 D4 A8L W12]
Old 31st May 2024, 07:14 PM
In that thread I linked to in post #4 above, they mention about it being a permanent live, which is what some people prefer, so that its recording even when parked up. Obviously there is going to be a power drain, but that doesn't appear to be an issue for them. Finding a switched live in that area does seem to be the major issue. Horses for courses I suppose, and also depending on the type of dashcam.
Old 1st June 2024, 09:12 PM
There is a non-permanent live in there which is what mine is connected to.
Old 2nd June 2024, 07:53 AM
Whoops! Had to reread through it again, as there were countless questions about looking for a switched live, with no definitive answer. However, it's the one shown in the photo in post #11, where it's referred to as a 'Black Power+ Accessory Wire'. Same thing, different name.
