Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 8th July 2022, 08:03 PM
hunker7 hunker7 is offline
Default 06' A8 - few issues
New to D3 and there are few issues I'd like to resolve and need some advice from the professionals.
First being after windscreen replacement auto lights don't won't anymore, permanently on, where would one start?
Second is error code for both engine mounts, solenoid open circuit? Is this fixable or required new mounts?
Old 9th July 2022, 07:43 AM
Windscreen - Two possible reasons
1. They used the 'cheese wire' method to remove the windscreen and cut through the wire (#31) in the attached image.
2. The wire (#31) wasn't cut when removing the windscreen but wasn't connected again.
Part number for the wire is 4E0970291 (£15).
Engine mounts - Most people tend to live with them being faulty, especially at £400 each.
Name:	A8 D3 Auto Headlight Sensor.png
Old 9th July 2022, 08:55 AM
There's an OE retrofit-bodge for the engine mounts I think, which is just a plug with a resistor in it to make the light go out. Can't remember where I've seen it though.
Old 9th July 2022, 06:44 PM
homer simpson's Avatar
I've seen this somewhere too but struggled to find it when I was looking! Damn wish I saved the part number lol. I'm sure ETKA didn't list it either
Old 9th July 2022, 07:24 PM
I'm not a D3 owner but even my first reaction was to recall seeing exactly that many times, a problem not worth solving!
Old 10th July 2022, 07:23 AM
Have seen mention of a TSB for the engine mounts but can't find any specific details about it. However, I did come across several references in relation to similar issues on A4s and A6s, with one comment for a DIY solution being a 19ohm resistor. The issue seems to be more pronounced on these cars as 034 Motorsport actually sell a 'resistor bypass connector':
https://store.034motorsport.com/resi...udi-s4-v8.html
Old 11th July 2022, 10:26 AM
Checked and wire is intact and plugged in on both ends, next stop I'd imagine is replacing rain/light sensor?
As for engine mounts, they're not triggering EML and I can't say there is much difference in smoothness I guess, just noticed a code that won't go away.
Old 11th July 2022, 04:57 PM
Assuming the sensor is at fault, there are two versions:
1. Light sensor only - 4E0907262 ~£85
2. Light AND rain sensor - 8K0955559A (~£215) or superseded with 8K0955559D (~£235)
Old 11th July 2022, 04:59 PM
If it was done recently and stopped working since, I would get them back out to sort it
As for the engine mounts, try and get a visual on them, if they look OK and the ride seems good along with no engine shake on idle/start up, I would leave them for now
Old 12th July 2022, 10:31 AM
Checked wiring again and all good, and sensor don't look healthy as it seems it needs to be filled with gel. So I'll look out for new one.
ID:	28749   Click image for larger version
