Clips for lower door trim
Anyone happen to know the part number? my drivers door trim is making a bid for freedom
Have you checked that parts are actually missing? Mine was hanging off and it turned out it had just "popped off" a couple of clips. Removing carefully and refitting properly sorted it.
IIRC there's a retaining screw on the inside and with that removed it just slides off backwards. Might need some gentle persuasion if it's a bit cruddy behind.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Parts catalog is on 7zap.com
Left side - 4D0854721
Right side - 4D0854722
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
to update
I checked and luckily nothing was actually broken, just needed me to remove the trim fully, reattach all the clips and replace. So for the benefit of anyone else finding this in the search in future....... This is a push on trim on the inside of the door, just pull it off underneath there is a self tapping screw at each end. These lock into the plastic clips pnm the outside of the door. Remove both screws. On the outside remove the trim panel. If like mine all of the plastic clips stay on the door. They need to be removed and put back onto the trim strip As you can see they simply slide to the left and pull off reattach to the silver are of the door strip below. each clip has 3 tabs that need to be squeezed into place with a small flat blade screwdriver once done offer the trim up to the door and with all clips aligned push on and slide toward the front of the door. the trim will then lock into place. I make that sound simple, its a bit fiddly as each of the clips needs to be exactly lined up art the same time. However with a little patience its doable. When you've done that, put the self tapping screws back from the inside and replace the internal trim cover. It just snaps into place Last edited by Markiii; 1st September 2023 at 12:22 PM. |
Pretty sure that's exactly what I had to do not that long ago; thought I'd documented it here (as mentioned above), though definitely not in so much detail.
