Closed Thread
Old 20th January 2009, 05:38 PM
Default Engine Bay Repair Sticky
Here we will post links to Engine related solutions. This post will be edited by an Administrator when a new solution is found either within this forum or elsewhere on the Interweb.
To Start the Ball Rolling here are some classic links from Paul W's Audipages. This site can't be recommended enough as a gold mine of information about your 8.
Breather Hose replacement - Audipages
CAMBELT CHANGE ABZ 4.2 V8
4.2 ABZ Engine Cambelt Change Procedure
- Audipages
Part Numbers for above Cambelt Change
- Audipages
The Tools You'll need
- Audipages
OTHER TASKS
Cooler expansion Tank Replacement
- Audipages
Cooler Expansion Tank Replacement
- Entwisi
Engine Fan (Electric) Removal and Replacement
- Audipages
Engine Removal and Re-installation
- Conan the Librarian
---------The Story Behind the Engine Change - Conan the Librarian
Fuel Line Leak (High Pressure) Repair Procedure
- Audipages
Fuel Tank Sending Unit Seal Replacement
- Audipages
VW Audi Oil Spec Information - DavidS8
Oil and Filter Change (32 & 40 V)
- Audipages
Oil Cooler Removal and Re-install
- Audipages
Spark Plug replacement
- Audipages
Valve Cover Gasket Replacement
- Audipages
Compression test results ABZ
- ainarssems
40V Intake manifold fix for stuck or sluggish flap pivots (no broken parts) - SilverD2 from Audiworld
Symptoms and their Explanations
Noisy Tappets
- Architex_mA8tey et al
The ultimate guide to the V8 and other resources
- R8dream
Manifold flaps repair document pdf -
Download this document which will both explain it all and show a way to possibly fix stuck flaps
http://forum.a8parts.co.uk/attachmen...9&d=1578778374
Remember, if you find a solution to a problem you've had or others have posted on the web let an Admin know (PM or email) and we will add it to this sticky.
Closed Thread
