windscreen washer jet FL
is it possible to remove one of these jets without damaging anything ?
whereas the jet on the drivers side gives a healthy spray , the one on the passenger side gives no more than an occasional weak dribble , barely reaching the screen ...this despite cleaning the holes with a suitable diameter needle presumably the same pump feeds both so there must be a blockage in between the pump and the jet , maybe in the jet assembly itself ? |
I had issues with the passenger side on side just prior to the MOT. Tried the needle method, but it didn't help. What I ended up doing was removing the tubing from the jet, and then using a small syringe, forced hot water back down the jets, which cured the problem. I suspect that over the years, gunge somehow accumulates at the base of the jets, blocking them. By forcing water through them the wrong way seems to clear them.
wonder why it is the passenger side , maybe the pressure is a little less ! just about to have my annual flu jab so the syringe should be just about the correct diameter needle ! |
I think they get bunged up with limescale due to the heating elements.
Even though they only clip in, to get them off you do really need to remove the wipers then the whole scuttle panel so as to easily disconnect the wiring and pipes. I have a spare (used) pair (long story!) that I soaked in kettle descaler for a while; lots of bubbles came off and they flowed much better afterwards. You could disconnect the piping near the wiper motor, I think there's a joint there with a non-return valve, and syringe some descaler through from there?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Take them out and soak them in descaler for a week. Kilrock's the best. The only way, I'm afraid.
Zip
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black (), heated rear seats, extended Leather Pack 3, blinds, glass sunroof, MFSW, Dension Gateway 100 for iPod, ski-hatch, xenon plus, auto dimming mirrors, 20" FE wheels, billet aluminium 'brake block', gunmetal Brembo calipers 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
I use this stuff neat: https://uk.hg.eu/products/sanitary/h...ale-remover-1l
Though I buy it in 5L containers as we live in a VERY hard water area. (And yes, we do have a working water softener!)
It could simply be the connection just before the passenger side jet has worked loose, this used to happen to mine a few times till I cable tied it on, easy to check
Audi S8 2002, Black (even the chrome bits) Audi RS6 Avant 2008, Daytona Grey Maserati Granturismo 2008, Metallic Nero Carbonio Audi S8 2015, Daytona Grey Last edited by briang9; 4th November 2018 at 10:57 PM. |
Should have clarified earlier. Don't use the needle. Just put the end of the syringe over the jet and force the water through.
well , cured ...sort of
having had no luck in cleaning up in situ I followed andrew's idea of taking off the wipers [ big job...probably never been off in 18 years ] and removing scuttle cover [ using angle grinder to cut off the centre bolt having cut away plastic ] ; easy to undo water tube from pump , also heater wires after that , next door for high pressure air through jets and pipes which cleared whatever was blocking the system why sort of ? one of the wires to the passenger side heater was broken off so presumably have to source an identical jet preferably with the wire back to the connector by the wiper motor anyway , no MOT problem with this at least ! thanks all for your contributions |
Zip
