#31
All covered by the "board", or in my case a lovely piece of thick black plastic material manufactured by Sean.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 9th December 2019 at 01:09 PM. |
#32
I have this (picture below), PM me if you need it at all. I'll send it to you.
You could use it as a template for making up your bridge wire if you decide to go down that route. If you don't use it in the end, just send it back.
#33
How come you have that kicking around? I've already made up a wire, using 6.3mm tags as MJ suggested. I'll try it another day though, once I've worked out EXACTLY which holes to bridge - don't want to blow a fuse somewhere!
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 9th December 2019 at 02:07 PM. |
#34
I have a real paranoia about needing something to keep my car running that becomes NLA. Thus I spend a fortune on buying random bits just incase I need them. This was bought, along with the other footwell relays from a8parts.
I'll send it out tomorrow morning.
#35
This is just a FYI, following Andrew identifying the relay, part number 431951253H.
Searching ETKA for that part number shows it was used in the A8 up until 1999, and is listed as being used 'for vehicles with auxiliary heater'. It then shows that it was superseded in 1997 with part number 141951253B, in 2005 with 8D0951253A, in 2007 with 8K0951253, and finally in 2010 with 4H0951253A. Searching for 141951253B instead against Andrew's car reveals two instances of it, in positions 1 and 2. Position 1 just lists location and code (204), with an 'automatic' comment against model. Position 2 lists 'relay switch for seat adjustment' (which doesn't seem present in Andrew's photo - odd!). The two green items are 30A thermal fuses, and the two 373 relays Andrew refers to are for 'day driving headlights and 1st stage radiator fan' in position 4, and '2nd stage radiator fan, fuel pump and fuel cooling' in position 5. You'll have noticed that there is no position 6 as shown in the wiring diagram illustration I uploaded previously, as in ETKA the two thermal fuses are both allocated position 3, with the relays being 4 and 5. If that isn't confusing enough, ETKA also lists part number 8D0951253A for Andrew's car, despite that part not becoming available until 2005. So, although we have two 'official' sources of information for all this, there is still inconsistencies.
#36
I'd already come to the conclusion that the various technical sources were a combination of vague, confusing, inconsistent and just plain wrong!
Which is why I decided on extreme caution, took it apart, looked and took photos.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
#37
No blank/unused switches on my car though, even the blank space to the right of the steering column has a switch now, for video-in-motion.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 9th December 2019 at 05:58 PM. |
#38
https://i.imgur.com/oJV8rhF.jpg Or, plenty of room under the armrest: https://i.imgur.com/ZSjGycc.jpg
#39
The gear shift button would be a subtle one to use, I think it just operates a mechanical interlock.
However I think it would be quite difficult to engineer and make reliable as the wires would flex regularly.
#40
BUT I did find the scuttle full a few weeks ago, so I reckon it's probably overflow from that and has just stayed there since. The fact that it's almost all just on the nearside supports that, I think the overflow from the scuttle always comes through there. Aircon drains overflow both sides. Anyway, fingers crossed, but I'll take out the (easier) passenger side trim soon and check/clean before I finish this job.
