Old 19th May 2023, 09:22 AM
Toblahoe Toblahoe is offline
Default Strange electrical issues
Hi all, I had a strange electrical surge/short the other day which created a tonne of error codes but they cleared straight away and it hasn't come back.
So, I was driving to Manchester with a friend to pickup a car for him, it's about a 2 hour drive for me it's probably the longest continuous drive I've done in the S8 since I bought it. Car drove flawless the entire way. We got about 30 seconds from our destination and suddenly the car jerked/jumped and all the dash electrics went off. Everything suddenly lit back up and I had a red "Brakes!" warning message that went away as soon as it appeared. I turned the engine off, waited a few seconds and started it again, no warning lights or nothing so we drove down the road to our destination.
Whilst my friend was viewing this other car I used my carista (I have VCDS I just need to buy a new laptop) to scan the codes and it displayed the attached. I cleared the codes and almost everything has disappeared and not come back, the only stuff that has returned are the items I am aware off such as the wiper motor control and tweeter motors.
Transmission:
49478
P0562 - Ultrasonic sensor right for theft alarm system (G171)
ABS:
02083 - Message for Delay Request
01299 - Diagnostic Interface for Data Bus (J533)
01315 - Transmission Control Module (TCM)
01314 - Engine Control Module (ECM)
Parking brake:
00456 - Control Module for Access and Start Control (J518)
00576 - Terminal 15
02443 - Control head
02596 - Rear brake pads worn
Instrument cluster:
00668 - Supply Voltage Terminal 30
Radio:
00532 - Supply Voltage B+
00447 - Function Limitation due to Voltage to High
00856 - Radio Antenna
Sound system:
03017 - Motor for Tweeter front-left (V344)
03016 - Motor for Tweeter front-right (V345)
03000 - Amplifier for Digital Sound package (R184)
TV tuner:
Heater & air conditioning:
00065 - Left Rear Footwell Heater (Z42)
00066 - Right Rear Footwell Heater (Z43)
00604 - Potentiometer (G113) in Positioning Motor for Air Flow Flap (V71)
Auto-leveling suspension:
01400 - Suspension Level Control
Central electronics:
00908 - Control Module for Wiper Motor
Body/convenience system:
01134 - Alarm Horn (H12)
Driver's door:
00913 - Window Regulator Switch: Front Right (E81)
Ignition authorization:
00191 - Passenger's Door Handle Touch Sensor (G416)
00955 - Key 1
Battery regulator:
02272 - Static (Quiescent) current stage 1
02273 - Static (Quiescent) current stage 2
02276 - Static (Quiescent) current stage 5
02274 - Static (Quiescent) current stage 3
02277 - Static (Quiescent) current stage 6
Roof electronics:
00211 - Control for interior lights in the back
02138 - Activation for Right Front Interior Lights
00308 - Supply voltage engines sun roof/Rolo sun roof
Adaptive cruise control:
01316 - ABS Control Module
The car drove back fine, although I did drive it without radio and the head unit was turned off. And it has not done it since.
Any ideas where to start with this?
Old 19th May 2023, 07:05 PM
Please post a full unedited VCDS scan. You've cut so much information it's impossible to make any suggestions.
Matt
Old 19th May 2023, 07:47 PM
In addition to what Matt said, can you provide the full scans of before and after. You can add the full scan using the CODE option, which will add the full scan details within a scrollable region within your post, to keep it neater. When you're replying, click on the # symbol on the second line of icons above the reply field. That will insert the text CODE surrounded by square brackets followed by /CODE surrounded by square brackets, with the cursor between them. Just paste your scan in there.
Old 21st May 2023, 09:01 AM
Thank you, unfortunately, that's all Carista will show me, I will get a laptop sorted so I can do a full VCDS scan.
Old 21st May 2023, 09:13 PM
monkeyboyuk monkeyboyuk is offline
Maybe someone local to you can help with vcds…?
2014 D4, FL 3.0tdi, phantom black, sport exec lwb
2002 D2 S8, Aqua Blue Pearl, original bar FE alloys and miltek
1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting….
1990 2.3 20v 7a Coupe Quattro
**SOLD** 1996 2.6 v6 cabriolet, Isis red metallic
**DEAD ** 2009 D3, 3.0tdi sport, black
Had a few Audis over the years, mostly early stuff, newest was a D3 prior to my D4, nothing much kept me smitten with other marques so I floated about a bit from one thing to another until that four ring lure caught hold
Old 2nd June 2023, 08:46 AM
Thanks all, my repaired laptop should be arriving tomorrow afternoon, will post VCDS scan here tomorrow night/Sunday.
However the car hasn't done anything similar nor has it had any further electrical issues (aside from Auto Wipers, It looks like the gel pad needs replacing).
Old 3rd June 2023, 12:17 PM
As promised, see below unedited VCDS Scan
Code:
Saturday,03,June,2023,13:17:45:49881
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN:    License Plate:
Mileage: 95170km-59135mi   Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 11 31 13 15 16 17 19 1E 28 34 36
          37 38 42 46 47 4F 52 53 55 56 57 61 62 65 6C 72 76
VIN:    Mileage: 95170km-59135miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels:. 07L-910-552-BSM1.clb
   Part No SW: 4E0 910 552     HW: 4E0 907 552
   Component: 5.2L V10/4V FSI    Ŗ0060
   Revision: 5AH21---    Serial number: AUX3Z0G6727503
   Coding: 01060003190F0260
   Shop #: WSC 63314 001 1048576
   VCID: 5F9BB094FB31B162561-800A
   VINID: 9D196AAAA115207780086085040FEAB896
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E2 910 156 C    HW: 09E 927 156 B
   Component: AG6 09E 5,2 FSI RdW 0020
   Revision: --H01---    Serial number:        0110368
   Coding: 0000001
   Shop #: WSC 02313 758 00200
   VCID: 2411FF7892D7D2BA4B3-8070
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 D    HW: 4E0 614 517 AB
   Component: ESP 5.7 allrad  H49 0500
   Coding: 0001927
   Shop #: WSC 02313 000 00000
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 907 181 C
   Component:     FBS AUDID3  H12 0200
   Revision: 02005112    Serial number: AUX3Z0G6727503
   Coding: 0413184
   Shop #: WSC 02311 785 00200
   VCID: 58E99B889E1F465A17B-800C
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: ELV                 XXXX
1 Fault Found:
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 3
                    Fault Frequency: 14
                    Reset counter: 117
                    Mileage: 94256 km
                    Time Indication: 0
                    Date: 2023.04.30
                    Time: 20:42:50
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
Address 07: Control Head        Labels: None
   Part No SW: 4E0 910 769 N    HW: 4E0 035 729 A
   Component: Interfacebox    H43 1480
   Revision: 00000000    Serial number: 347FQ077516035
   Coding: 0000108
   Shop #: WSC 11274 001 1048576
   VCID: 372B38343341A922FE1-8062
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0040
   Subsystem 2 - Serial number: 00000000041979
   Subsystem 3 - Serial number: 0103.07.070000000100010079˙
   Subsystem 4 - Serial number: 010079˙
Address 08: Auto HVAC        Labels: None
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000128413
   Coding: 0123601
   VCID: 1C61C798AAA7EA7AF33-8048
3 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 95145 km
                    Time Indication: 0
                    Date: 2023.05.26
                    Time: 07:32:12
             Freeze Frame:
                    Voltage: 13.30 V
00066 - Rear Right Footwell Heater (Z43)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 46
                    Reset counter: 76
                    Mileage: 91968 km
                    Time Indication: 0
                    Date: 2023.03.09
                    Time: 11:54:16
             Freeze Frame:
                    Voltage: 14.30 V
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 94
                    Mileage: 93778 km
                    Time Indication: 0
                    Date: 2023.04.22
                    Time: 07:17:02
             Freeze Frame:
                    Voltage: 14.30 V
                    (no units): 174.0
                    (no units): 255.0
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No HW: 4E0 907 279 Q
   Component: RLS NO RESPONSE
   Coding: 0133001
   VCID: 55F792BC890D7B320CD-8000
3 Faults Found:
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 76
                    Mileage: 94676 km
                    Time Indication: 0
                    Date: 2023.05.17
                    Time: 17:46:26
01520 - Rain and Light Recognition Sensor (G397)
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 76
                    Mileage: 94676 km
                    Time Indication: 0
                    Date: 2023.05.17
                    Time: 17:46:26
02071 - Local Databus
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 1
                    Fault Frequency: 83
                    Reset counter: 117
                    Mileage: 94678 km
                    Time Indication: 0
                    Date: 2023.05.17
                    Time: 17:49:13
Address 0E: Media Player 1        Labels: None
   Part No SW: 4E0 910 121     HW: 4E0 035 121
   Component: MD-Changer      H42 0070
   Revision: 00000001    Serial number: KE1059V7500190
   Shop #: WSC 00000 000 00000
   VCID: 57EB98B4930149221E1-8002
Address 11: Engine II        Labels:. 07L-910-552-BSM2.clb
   Revision: 5AH11---    Serial number: AUX3Z0G6727503
Address 13: Auto Dist. Reg        Labels: 4E0-910-561.clb
   Part No SW: 4E0 910 561 F    HW: 4E0 907 561 F
   Component: ABSTANDSREGELUNGH03 0020
   Coding: 0041148
   VCID: 2517E27C99ED2BB25CD-8070
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H14 4210
   Revision: 91H14421    Serial number: 0037P0G0FS5D
   Coding: 0430707
   VCID: 270BE874E3E139A26E1-8072
   Subsystem 1 - Serial number: 63328RB402B9EE23X
   Subsystem 2 - Serial number: 63428RB402B9F085T
   Subsystem 3 - Serial number: 63528RB402B9EFE24
   Subsystem 4 - Serial number: 63628RB402B9F0DB%
   Subsystem 5 - Serial number: 63729RB402915BC5S
   Subsystem 6 - Serial number: 63829RB402915BF1S
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549 A    HW: 4E0 953 549 C
   Component: J0527               0410
   Revision: 00H04000    Serial number: 90025071860086
   Coding: 0112151
   VCID: 2615E570E4EB20AA557-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 931 N    HW: 4E0 920 931 N
   Component: KOMBIINSTR. VDO H82 0530
   Revision: D05         Serial number: AUDID3G6001400
   Coding: 0048913
   Shop #: WSC 33268 002 1048576
   VCID: 2E051D50CC1B68EAAD7-807A
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4E0 907 468 G
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0100J077138055
   Coding: F5F5DFFF71260E
   VCID: 6C81D7583A87DAFAC33-8038
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 B    HW: 4E0 035 110
   Component: MP3-Changer     H46 0350
   Revision: 00046004    Serial number: AUZ5ZBG2030766
   VCID: 176BD8B453818922DE1-8042
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4E0 910 158     HW: 4E0 919 158 D
   Component: KLIMA-STG. FOND 017 0230
   Revision: 00000020    Serial number: 00000000057436
   Coding: 0000000
   VCID: 619FB66CCD458792605-8034
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 L    HW: 4E0 907 553 H
   Component: LUFTFDR.-CDC    H07 6340
   Coding: 0015510
   Shop #: WSC 56676 001 1048576
   VCID: 2C011758FA071AFA833-8078
1 Fault Found:
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 94882 km
                    Time Indication: 0
                    Date: 2023.05.20
                    Time: 12:24:27
Address 36: Seat Mem. Drvr        Labels: None
   Component: Sitzmemory FS  H02  0010
   Coding: 4063338
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 888 K    HW: 4E0 919 887 B
   Component: MNS JP          H04 0590
   Revision: 0000005S    Serial number: AUZBZ7G0105064
   VCID: 36353530344B502AE57-8062
   Subsystem 1 - Part No: 4E1 910 336
   Component: Interface Handy H08 0050
1 Fault Found:
02288 - Control Module for Chip Card Reader (J676)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 43
                    Mileage: 94503 km
                    Time Indication: 0
                    Date: 2023.05.06
                    Time: 15:28:58
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H05 0090
   Serial number: 00000718400012
   Coding: 0036006
   Shop #: WSC 64595 001 1048576
   VCID: 1D67CA9CB1BDE37204D-8048
1 Fault Found:
00211 - Control Circuit for Rear Illumination Lights
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 15
                    Reset counter: 76
                    Mileage: 94392 km
                    Time Indication: 0
                    Date: 2022.04.30
                    Time: 22:50:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 D
   Component: Türsteuer.FS BRM005 0180
   Coding: 0032750
   Shop #: WSC 02313 785 00200
   VCID: 2019F36886CFCE9A2FB-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
   Component: Komfortgeraet   H08 0020
   Revision: 00200008    Serial number:  W040707310094
   Coding: 0004840
   VCID: 2A0D1140F0F304CA71F-807E
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel   P27H08 0090
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 77
                    Mileage: 90046 km
                    Time Indication: 0
                    Date: 2022.01.15
                    Time: 10:30:14
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 77
                    Mileage: 90046 km
                    Time Indication: 0
                    Date: 2022.01.15
                    Time: 10:30:14
02107 - Trunk or Luggage Compartment Opening Motor (V254)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 105
                    Mileage: 95051 km
                    Time Indication: 0
                    Date: 2023.05.21
                    Time: 10:55:58
Address 47: Sound System        Labels: None
   Part No SW: 4E0 910 466 B    HW: 4E0 035 466
   Component: BO_D3           H06 0180
   Revision: 20S00002    Serial number: 01903070008472
   Coding: 0000017
   Subsystem 1 - Part No: 4L0 910 465 A
   Component: BO_D3_SLAVE     H41 0780
   Subsystem 2 - Serial number: 01304120020030
   Subsystem 3 - Serial number: 0213.04.120000000100010030˙
   Subsystem 4 - Serial number: 010030˙
3 Faults Found:
03017 - Motor for Left Front Treble Speaker (V344)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Reset counter: 77
                    Mileage: 91968 km
                    Time Indication: 0
                    Date: 2023.03.09
                    Time: 11:55:27
             Freeze Frame:
                    Voltage: 12.70 V
                    Temperature: 16.0°C
                    Bin. Bits: 00000100
                    Voltage: 12.50 V
                    Temperature: 20.0°C
03016 - Motor for Front Right Treble Speaker (V345)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 77
                    Mileage: 91968 km
                    Time Indication: 0
                    Date: 2023.03.09
                    Time: 11:55:27
             Freeze Frame:
                    Voltage: 12.70 V
                    Temperature: 15.0°C
                    Bin. Bits: 00000100
                    Voltage: 12.50 V
                    Temperature: 20.0°C
03000 - Amplifier for Digital Sound Package (R184)
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 77
                    Mileage: 91968 km
                    Time Indication: 0
                    Date: 2023.03.09
                    Time: 12:24:22
             Freeze Frame:
                    Voltage: 11.90 V
                    Temperature: 16.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.50 V
                    Temperature: 30.0°C
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 B
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000008261
   Coding: 0010101
   VCID: 1E65CD90BCBBF86A1D7-804A
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 D
   Component: Türsteuer.BF BRM005 0180
   Coding: 0032750
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
   Component: EPB  A4EC0230   H03 0230
   Revision: --H03---
   Coding: 0000733
   Shop #: WSC 09308 002 1048576
3 Faults Found:
01487 - System Function Test
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 81
                    Mileage: 94392 km
                    Time Indication: 0
                    Date: 2023.04.30
                    Time: 22:50:23
             Freeze Frame:
                    Voltage: 11.90 V
                    Count: 32
02443 - Control Head
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00111100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 81
                    Mileage: 94392 km
                    Time Indication: 0
                    Date: 2023.04.30
                    Time: 22:50:23
             Freeze Frame:
                    Voltage: 11.90 V
                    Count: 40
02596 - Rear Brake Pads Worn
             Freeze Frame:
                    Fault Status: 01111000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 41
                    Mileage: 94064 km
                    Time Indication: 0
                    Date: 2023.04.30
                    Time: 17:44:23
             Freeze Frame:
                    Voltage: 11.59 V
                    Count: 61
Address 55: Headlight Range        Labels: 4F0-910-357.lbl
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Component: AFS 1           H01 0020
   Coding: 0000018
   VCID: 290FEE4CF5F50FD2785-807C
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
Address 56: Radio        Labels: 4E0-910-541.lbl
   Part No SW: 4E0 910 541 N    HW: 4E0 035 541 R
   Component: TUNER Japan     H42 0180
   Revision: 00000000    Serial number: 325GN077535052
   Coding: 0000003
   VCID: 2B031444FF091DC28A9-807E
1 Fault Found:
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 19
                    Reset counter: 108
                    Mileage: 91968 km
                    Time Indication: 0
                    Date: 2023.03.10
                    Time: 13:25:35
Address 57: TV Tuner        Labels: 4E0-910-146.clb
   Part No SW: 4E0 910 146 F    HW: 4E0 919 146 C
   Component: TV analog TUNER H15 0290
   Revision: 00000076    Serial number: 00000000015579
   Coding: 0000016
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000010459
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  341126Q0W1
   Coding: 344530393135313035412056413033343131323651305731
   Shop #: WSC 65372 001 1048576
1 Fault Found:
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00110001
                    Fault Priority: 7
                    Fault Frequency: 4
                    Reset counter: 101
                    Mileage: 94700 km
                    Time Indication: 0
                    Date: 2023.05.18
                    Time: 05:10:15
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: Türsteuer.HL BRM005 0180
   Coding: 0032750
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05
   Revision: 00050340    Serial number: 00000600058977
   Coding: 0222428
   Shop #: WSC 11918 001 1048576
Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
   Part No SW: 4E0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J77109R
   Coding: 1121402
   VCID: 5CE18798EA27AA7A333-8008
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0032750
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08730720812861
   Coding: 0221008
   VCID: 2313FC6497D9D582329-8076
End----(Elapsed Time: 02:25, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Toby
2007 S8 D3 5.2 V10 - Jap Import in Daytona Grey
2004 BMW X3 2.5i Manual (Old Workhorse)
Previous:
2009 S5 4.2 V8 - Phantom Black with Red leather interior
2006 A4 3.0tdi Manual - Black with Black Leather
2001 BMW 323ci 2.5i Manual
Old 5th June 2023, 11:22 PM
Was enjoying a long overdue drive with other A8/S8 owners on Saturday at our 2023 (rescheduled 2020) annual meet, so missed this.
Address 05: 00191 - Typical issue with the door handles as they fail over time. I've seen it mentioned elsewhere to just disconnect the cable going to the door handle for the sensor, but never tried it.
Address 08: 00065 & 00066 - Another typical issue that affects older cars. The footwell heaters basically consist of a large heatsink with four transistors bolted to them. All held in with some sort of epoxy, so you can't get at them without destroying them. Most people just live without them.
Address 08: 00604 - One of the flap motors has an intermittent fault. Since you now have VCDS, you can go into Address 08 and run tests on them. It's been a while, but I think you can run Basic Settings for individual motors, and the issue might be that the motor is failing or that it is out of the allowable range. Worth checking and running that before replacing. The following PDF has instructions of how to replace. Just search for G113:
http://forum.a8parts.co.uk/attachmen...3&d=1420367102
Address 09: 00908, 01520 & 02071 - Did some Googling on this and came across the following thread. Problem was with a Q7, but the same error codes as yours. Some more details can be found in SSP287. It's worth going through the entire thread to check things with VCDS, but their solution was replacing the J519 module (which has component protection), possibly caused by the car being jump started:
https://mhhauto.com/Thread-HELP-Plea...326#pid1057326
Address 34: 01400 - Could be a bad level sensor or a faulty connection to it. It might even be detached. Check them first and then use VCDS to check the measuring blocks. Change the settings in the MMI and see if VCDS shows corresponding/matching changes.
Address 37: 02288 - Weirdly, the VCDS Wiki doesn't even give details for this error code. Some searching did find the following thread, with the only common feature being that is was a Japanese import, although their issue was with coding the radio to work in Ireland:
https://forums.ross-tech.com/index.php?threads/19743/
Address 38: 00211 - Another one that shows nothing in the VCDS Wiki, with the only 00211 being a coding reference. From the description, maybe just a faulty connection in one of the rear roof lights or switches.
Address 46: 01134 - Yet another common faults with most VAG vehicles. The battery inside the alarm horn deteriorates and causes a short on the PCB, or destroys it completely.
Address 46: 02107 - The motor may just be stuck. Those with the plastic casing tended to be less up to the job and would sometimes struggle. One solution would be to try dismantling and applying violin rosin on the clutch wheel. The newer ones with a metal casing are better as they have a stronger motor.
This has taken longer to respond to than I expected, so I'll continue tomorrow.
One comment about the scan. You don't mention if any of these error codes are showing any visible signs like warning lights on dash or items not working e.g. for 'Address 09: 00908, 01520 & 02071' do the wipers work?
Old 7th June 2023, 07:34 AM
Thank you for the detailed reply Steamship!
There are absolutely no warning lights on the dash, the wipers are intermittent, if I unplug the connection to the wiper motor and plug it back in, they work fine until it rains.
Same for the footwell heaters, seems strange as they appear to work fine.
The radio/nav errors I am fine with as it's a Jap car it doesn't work anyway, I use a bluetooth/radio transceiver to listen to music, I'm currently looking at alternative options.
My main worry was the battery issue I had after a long drive, It hasn't replicated itself at all, but the furthest I have driven was Leeds since then. Overall I still love the car, I have valve cover gaskets and plugs arriving this weekend, I'll tackle that job as I can tell the original is very brittle and oil is leaking into the spark plug wells from the gasket.
Toby
Previous:
Old 8th June 2023, 08:50 PM
Sorry for the delay, but helping other family members with jobs the last few days.
Address 47: 03017 & 03016 - Do the tweeters work, and/or are they permanently up/down in the dash? If they don't move, either the motors have failed on both of them or someone disconnected them to stop they raising/lowering.
Address 47: 03000 - Would check the physical connections to the amplifier. Does the amp work? Maybe this issue is the cause of the tweeter codes.
Address 53: 01487 - Try clearing all three codes and then running the following test: http://wiki.ross-tech.com/wiki/index..._Function_Test
Address 53: 02443 - Two possible causes that I've come across. One is the EPB button is faulty, or has dirty contacts inside, the second being possible dodgy connections on the EPB module itself. Worth removing them and checking for signs of corrosion.
Address 53: 02596 - Two possible cases, the first being the obvious ones that the pads are worn. The second is that the pad thickness adaptation wasn't done properly the last time, in which case, you could try doing that. See the following link regarding Adaptation: http://wiki.ross-tech.com/wiki/index...#Pad_Thickness
Address 56: 00856 - Might possible be due to corrosion at the base of the shark fin antenna on the roof.
Address 61: 02256 - This basically means that something isn't going to sleep properly. The big issue is figuring what. From the other codes, I'd hazard a guess that it's been caused by the door handle.
Following on from your last response, I can only assume that the wiper motor has a faulty connection somewhere, as they reset themselves when you disconnect them. Do they stop working when it starts raining? Very odd.
