Go Back   A8 Parts Forum > A8 D4 > D4 - Everything Else
D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out
Old 20th November 2016, 04:44 PM
Well done made and a great guide
Old 26th November 2016, 05:47 PM
kal_ay's Avatar
kal_ay kal_ay is offline
Originally Posted by Albert_Swafega View Post
Well, pump arrived this weekend, installed, all is good in the world again..
Idiots guide, with photo's attached, hopefully it'll help someone else as much as a8parts forum has helped me over the last few months.
Albert
Thanks for this ,my job for next week
2002 D2 S8 Misano Red
1996 Volvo 850R Estate Red
2013 Mercedes C63 AMG (taxi)
1991 Lotus Carlton Imperial Green
Old 6th December 2023, 07:46 AM
Albert_Swafega Albert_Swafega is offline
Hi guys,
for info, the car is cold again, according to VCDS the pump failed at the end of August, but it's only recently turned cold enough to notice.
I've gone the aliexpress route this time, the last pump lasted ~5yrs.
https://www.aliexpress.com/item/4000833782805.html
Looks like i'm swapping it over the Christmas break
Albert
2011 A8 Executive 3.0 TDI Quattro
Old 6th December 2023, 07:48 AM
Hi guys,
Albert
Having looked back at my first post........it lasted ~7yrs
Old 6th December 2023, 08:19 PM
monkeyboyuk monkeyboyuk is offline
Mines is doing something similar but not quite the same and think I saw a similar message pop up about circ pump. I get heat randomly and nothing from dash vents. Only seems to blow windscreen n warmer on pass side. I also know the flap thing behind glovebox needs replacing
2014 D4, FL 3.0tdi, phantom black, sport exec lwb
1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting….
1990 2.3 20v 7a Coupe Quattro
Old 9th December 2023, 11:29 AM
I'd bet a tenner it's the pump.
The "random" heat you speak of, is it when you throw the car round a corner, and the momentum moves the water through the heater matrix?
Mine gets warmer if i drive it like i stole it
Old 9th December 2023, 11:58 AM
That statement brings back memories. I had a brand new Audi A4 back in late '95 that exhibited the same problem joining a slip road from a roundabout. Only happened on left turns.
Old 9th December 2023, 07:05 PM
Only time I had those symptoms was after a major service (long ago) at Audi when they didn't top up the coolant properly. Easily fixed by me.
Old 16th December 2023, 02:26 PM
Hi guys,
Albert
For info, the pump arrived the other day, and it's bloody different.
It works perfectly, the car is warm, and the fault has cleared in vcds, but the mounting holed were different.
I've adapted the mount slightly, so it fits, but "next time" i'll take more attention when ordering.
Albert
