#191
Before and after
My potion of choice - Gtechniq W5 All Purpose Cleaner, and a soft brush. This gets most of the dirt off and is just rinsed off with water. I use brake cleaner for the real heavy grease and oil (mostly on the other side), and I'm now also using Elbow Grease for lighter oily dirt. Elbow Grease is ok on heavy stuff if you use a stiff brush, but on paint I prefer to use the brake cleaner as it just dissolves it with much less effort and reduces the risk of scratches. After the various cleaning solutions, I blow it dry with compressed air, then go over with quick detailer to pick up the last of the smears. Almost there now. I need to deal with the snapped fasteners, and clean out the wheel arches, then I'll go over the whole lot with sealant to make it hydrophobic. |
#192
Murple is lush . I turned one down several years ago and have regretted it ever since. I could of had it for less than £2k as well
Good job as always MJ. The before and after are like night and day. Seems a shame to put the engine back in as no one can see all the lovely shiny-ness afterwards
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ) 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Ibis White |
#193
Wow MJ, you do amazing work!
2001 S8 (build date March 16th 2001) Brilliant black with oxblood red/black interior. Mods prior to my ownership: 01E 6 speed, carbon fiber trim, bi-xenon, aftermarket muffler with x-pipe, tinted windows, non-tip steering wheel, Spal electric fan. My mods: Oxblood red interior, LED interior lights, D3 ignition coils, new window tint, tip steering wheel with new S8 emblem, mk1 TT steering wheel air bag, mk1 TT 6 speed shift knob, new shift boot. |
#194
Thank you
Well, its still throwing up surprises I was going to clean the rain tray on the right hand side when... I discovered a hole in the underseal right in the corner. Poke poke poke, and there's a section about 2x3" where the underseal is loose and just falling off in chunks. After some cleaning with solvent and a wire brush, its basically bare metal and exposed seams. Water will have been getting in here since all the drains were blocked, but its been in the workshop for a year so nice and dry now Obviously I had to go and poke the other side I completely missed this when I was doing Botang's hole It came off in one huge chunk on this side - just spooged in there and not bonded at all, with dirt behind it. I cleaned both sides as thoroughly as possible with solvents (nothing water-based), then applied new seam sealer. I will wait for this to completely dry before cleaning this area any more. Started on the wheel arches. Cleaned with APC, then hit it with W7 Tar and Glue remover to dissolve all the tar spots. This stuff is great - spray on and the tar just melts away Second pass and its almost all gone If you're not standing in your wheel wells to get the tar off the wheel arch lips, is it even detailing? Driver's side nice and clean now The rack has definitely been out at some point. Remember the stupid-expensive rivets I mentioned earlier? This is one, used to replace a snapped body stud which gets in the way of getting the rack out. Its pretty much guaranteed that the butcher of Bristol didn't fit this (he would have used a self tapper) so I think this was done before it was 7 years old while it was still being maintained by Audi. The rack isn't a re-con and I have no receipt for the work so its unclear what was done, but it may explain why the hoses appear in much better condition than normal. Note - I bent it getting the rack out but it straightened out ok Passenger side done. Interestingly, just like Big Red, the chassis leg is lacquered on the left and not on the right! Does anyone know what this is and where it goes? |
#195
I assume that you know, MJ, and this is a teaser. Because if you really don’t know, what chance have we mortals?
#196
Yes, I know what it is
#197
I'd guess it's a seal or anti-vibration device of some sort, but the real mystery is why the four conical plug shapes?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
#198
Is it something to do with the radiator?
#199
MJ, having cheated to find out what it is, you need to give us mortals easier ones to give us any chance of knowing.
A suggestion for you for when you finish the car. Post a photo of the one single item you didn't have to fix!
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
#200
I'm intrigued how you found out what it is without a part number? |
