When I change the rear breathers I will check all other vacuum/ breather pipes back there as well, especially any attached to the Idle valve or throttle body.
Hope I find the cause because SWMBO is fed up with it stalling in traffic jams has suggested its time for it to go. Any other suggestions to check greatly received as I do not want to sell it, even though its done over 170,000 miles
2002 S8 Final Edition, Avus Silver with Red leather interior Guildford, Surrey Tiptronic with Sport mode button. Sony rear entertainment package. Bose sound system. Audi Navigation Plus. 20 inch Final Edition alloys Full Cat Back Stainless Milltek exhaust, giving a great V8 burble : 1997 A8 Quattro Sport - Now sold when S8 FE purchased |
Well I changed the rear breather pipes, which both had small holes in them. The small breather pipe to the throttle body was also blocked, so changed that as well. Checked all other breather/vacuum pipes which all seemed okay. Reset the idle valve using VCDS. Unfortunately this has made no difference. In fact, if anything it has made the stalling worse. Will try replacing the idle valve again from our sponsors to see it this helps, once the one they have appears in the sale. £60 is to dear. Last one I bought was in the sale at £30
If this does not work I don't know where to turn next. Anymore suggestions guys or any recommendations as to where I can take it to someone who can sort this problem once and for all
have a search on quattroworld.
here is a post that could be similar to your situation? http://forums.quattroworld.com/a8/msgs/88539.phtml |
I had issues like this some time ago. One suggestion to stop it stalling was to switch the A/C Econ off. Mine was related to the vacuum pipes. The front ones were easy to see and replace, but it was the ones at the back of the engine that were the issue. On one side of the engine, the pipe was starting to perish and on the other side, the pipe had disappeared completely. There was a gap of about two inches to where it should have connected to the one way check valve.
There is a set of instructions (with pictures) on the audipages site: http://www.audipages.com/Tech_Articl...sereplace.html
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
Both of those links are for FL, OP's car is PF so vacuum hoses are a bit different. But symptoms does sound like incorrect reading for measured air either because of bad/dirty MAF or air/vacuum leak.
