D3 - Body and Exterior Bumpers, bonnets, glass, trims - Everything outside |
No, before my driver door handle had it's latest issue, it would unlock as I approached the car. This then reduced to unlocking only when pulling the handle once, and then reduced further its current state of not working at all.
I checked the owner's manual since -
Phantom Black 2008 A8 3.0 TDI SE ASB |
Interesting. So prior to the fault, if you walked towards the vehicle (and was close by), did the car unlock and indicators flash without you having to touch the handle?
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder |
If this is the case, I wonder if there is a setting in the MMI for this. Even though I have keyless entry/start on the S8, I rarely used it, and never gave the car a chance to use it if available, as I would use the remote to unlock the car as I approached it. I think I only ever used the Start button 2 or 3 times to see it in operation, as it doesn't lock the steering column when you press Stop (you have to press and hold it for a few seconds).
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
In my experience with fully working door handles the car doesn't unlock when you walk by, it only unlocks when I put my fingers under the door handle.
This is not pulling the handle, it sense proximity. If you need to pull the handle its not working as intended and if it unlocks as you approach the car i'd say that it thinks your fingers are below the handle, also not good.
Del |
2006 A8 d3 4.2tdi sport stoke-on-trent. |
I would agree that the sensor thinks something (the OP) are touching the handle and so unlocks when near by
I have a D4 and that is how mine works.
The D3 and D4 should function exactly three same, but three D4 improved the handle design as the "sensor" is a separate part, meaning when it goes faulty it can be fixed for about a tenner and boot need ant paint. Sadly in three D3, it gets expensive...
My car "wakes up" (you can hear the Bose amp fan in the boot start up)
when you walk by the handle with the key, But the car won't unlock until you put a hand under the handle. The lock buttons fail often but the button has only one moving part. I have found these handles can be reanimated if you unplug them, and clean the plug and handle contacts with contact cleaner. Water gets into the plug, and screws with the very small electrical resistance range the handle uses to work. Under the rubber button is just a spring and a metal plate the touches a contact on the handle body. Mike
04 A8 - 4.2 Sport Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension Auto Boot - Double Glazing - AMI - Solar roof TV - Bose - Voice Control - TPMS - AFS- TINT Power Blind, Fingerprint - Light package (in and out) Retrofits: OEM Auto headlights & rain sensing wipers OEM Bluetooth phone Bluetooth Audio Streaming Reverse Camera OEM Aluminium Package Auto boot close using remote/door button |
