Old 29th May 2022, 07:40 AM
Its surprising modern cars are still having issues with this.
Unfortunately the D2 spindles tend to wear very badly as they are chrome plated, which wears / rusts off, and then the spindles go oval The D3 spindles appear to be hardened and are longer than the D2 ones so I'm hoping to be able to put D2 arms on D3 spindles, replace the bushings, and fit balljoint linkages. When I get time...
Time hunt is the bane of our modern life. I've just woken up sprawled across the bed with an untouched cold cuppa on the bedside shelf. Last I remember is thinking I'll watch the news at ten last night. I was working on the computer until 04:00 yesterday morning so I guess it's my own fault.
Of course visiting very poorly friends during the day didn't help along with every spare minute working in the garden.
Perhaps my body is saying slow down a bit.
Now where did I put my time machine controller?
Old 29th May 2022, 08:24 AM
"Time flies like an arrow, fruit flies like a banana" Ray....
Old 29th May 2022, 10:31 AM
I'm curious about what type of screen you had and which Autoglass are replacing with. I've been waiting a while for them to contact me about my new screen, currently have heated and insulated so will lose the heating.
Just a standard S8 non-heated screen, with tinted band.
Old 29th May 2022, 07:39 PM
I removed the screen surround today ready for the new screen to be fitted tomorrow. As usual, several of the clips were rusty because of the butyl sealant the factory fitted at the base of the drain channel, seemingly deliberately to make the clips rust. These will be replaced once the glass is out.
Marcel came over to help so we put the bonnet back on - the colour match is very good.
The headlight rubber trims have rotted away, so these were replaced with pieces from a donor set of lights which I'm using for parts
The corner trim is sold as part of the lens, but it can be removed easily enough
Good as new
One of the aluminium trims on the bumper was past recovery, but luckily I had one which was in usable condition and which polished up to a similar state as the other side
I forgot to take any pictures of the front end all back together, but the car is now back on its wheels ready for Autoglass tomorrow. I'll be putting the interior back in before they arrive, and hopefully polishing up the rest of the brightwork before taking it to Nicola's
ID:	28581   Click image for larger version
ID:	28582   Click image for larger version
ID:	28583   Click image for larger version
ID:	28584   Click image for larger version
ID:	28585   Click image for larger version
ID:	28586   Click image for larger version
Old 29th May 2022, 08:29 PM
Good as new
And by the time you've finished, in many respects, better.
Old 30th May 2022, 08:29 PM
General putting-back-together today, and a new windscreen. After that was done I made a start on assessing which bits of brightwork can be recovered - some are beyond saving.
Some pieces come up ok
C-pillar trim
Engine bay almost done
Bunk beds tonight! I'm slightly behind the plan at the moment - it was supposed to be at Nicola's today but I still need to do some more on the engine bay and interior, and finish off the brightwork.
The silver one in the foreground is here for a service and thermostat while Andrew's is off being detailed, which hasn't quite gone to plan! So, Nicola is coming over tomorrow to work on the brightwork while I reassemble and swap over some pieces which can't be saved.
ID:	28607   Click image for larger version
ID:	28608   Click image for larger version
ID:	28609   Click image for larger version
ID:	28610   Click image for larger version
ID:	28611   Click image for larger version
Old 31st May 2022, 08:47 AM
I'm going to need some serious advice on maintaining the looks after you and Nicola have finished.
Old 31st May 2022, 10:51 AM
Pretty sure you've probably mentioned this in another WITW thread, but what do you use to protect the brightwork after you get them cleaned up?
Old 31st May 2022, 11:16 AM
I have that in hand
Old 31st May 2022, 12:08 PM
I have that in hand
Add me to the list of training / instructions as well please... we could make a day of it
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
