Old 23rd August 2016, 05:37 PM
1781cc 1781cc is offline
Default General questions
Just looking for some answers to general questions on the D3 FL S8
1 - Is the battery sealed or standard? I don't use her often enough to charge I think as I get intermittent battery warnings, clears after a long run, seems to tally with the boot motor working when the car is running and after runs but not if I've just pottering.
2 - Whats the button next to the steering column controls, its just a round in out job, can't see it doing anything
3 - How to I throttle memory potentiometer reset? she's a little jerky sometimes, I used to reset on my B6 S4 and it helped, don't know the process on this thing, is it the same as the D2
Thanks
Old 23rd August 2016, 05:47 PM
If it's the same as the D2, it's just an on/off switch for the steering column controls.
Old 23rd August 2016, 06:17 PM
Pug Pug is offline
1. Battery charge almost definitely low. Give it a full charge and invest in a battery maintenance charger. You'll find the battery level display in the MMI. Convenience features are temporarily disabled on a low battery charge condition. Failing that, buy a new battery.
2. The button on the left hand side of the steering column enables and disables the 'easy entry' feature. This is when the steering wheel moves up and away from you on ignition off, and back to the previous position with ignition on.
3. I'm not sure on resetting the throttle. I tried it once on a D3 S8, but not sure if it actually worked; it was very difficult to tell, since I still ended up getting whiplash when I brushed the throttle pedal with my toe.
Current: MY2019.5 Ford Ranger Wildtrak 2.0 BiTurbo
A8/S8 - A gap to fill.
Multi-Franchise Main Dealer during the day, Amateur vehicle enthusiast by night.
Old 23rd August 2016, 08:03 PM
Thanks for the replies, Pug - I have a charger conditioner but there is a switch for Standard and Sealed batteries so I don't want to make a guess and mess it up.
Anyone know what type it is? Any way of telling?
Old 23rd August 2016, 08:10 PM
Pug Pug is offline
Sounds like an older charger. Most batteries these days are maintenance free and do not require topping up like older batteries did. I would only use an auto-sensing charger, since it will stop charging when the battery is charged.
Old 24th August 2016, 08:47 AM
Just ordered a CTEK MSX7.0 from amazon, bargain at £93
Will hook it up and see what happens, means when I get the lithium Odyssey in the Track car I can use it for that after.
Thanks for the replies to questions
Old 24th August 2016, 12:49 PM
hmmm, just went out to the car and I can't find this anywhere... any pointers?
Old 24th August 2016, 01:17 PM
It was disabled in a lot of MMI updates as it was pretty pants tbh.
Old 24th August 2016, 03:24 PM
https://www.youtube.com/watch?v=EyqNki4NMWo
Old 24th August 2016, 04:04 PM
thanks for that, but tried it and I can't get into a hidden menu, the button combo doesn't work for me
