Old 30th January 2021, 10:03 AM
Default Rear centre console removal
I should know, as I’ve done this before, but how does the bit of trim, where the rear ciggy lighter and central vents are, come off? I’ve dropped the pivot for the handbrake cover trim down there! I suspect some gorilla tried to force the arm rest down with the handbrake on and broke it.
Old 30th January 2021, 10:05 AM
The wood trim just pops out. You can get a small flat screwdriver under it and lever it out. The vent unit then has two philips screws holding it to the console.
Old 30th January 2021, 10:09 AM
A reply in 2 minutes - brilliant! Thanks again.
Old 30th January 2021, 12:03 PM
Ah, yes, there are a couple of little ‘niblets’ at the lower edge of the trim that I got a plastic trim tool into and out it popped. I managed to retrieve the plastic ‘pivot’ (a yellow white cylindrical bit of plastic) but can’t work out how it fits back into place. And it’s too cold here to try fiddling about with it - my frozen fingers will just drop it back again!
If anyone can be bothered to post a diagram of how this fits together, I’d be very grateful. I know it’ll be here somewhere, but I’m hopeless at finding anything!
Old 30th January 2021, 10:14 PM
This is the one you're looking for Jim. Start at section 7 and from your description I believe it's item number 18 you're interested in.
Service Manual Brake System.pdf
Old 31st January 2021, 12:20 PM
Thanks Sean. That's the area that I'm after, but the thing I'm talking about doesn't seem to be there! It's not item 18; it looks a bit like item 14, but it's not that either. It fits into the slot on item 1, allowing it to move backwards and forwards with the handbrake movement.
Old 31st January 2021, 02:01 PM
Curiosity got to me so had to go have a look at mine... and now I'm even more confused from your description, mainly because I can't find a 'a yellow white cylindrical bit of plastic'.
Looking at the attached photo (severely cropped to hide the dirt!), my handbrake cover (sitting on its side) swivels on the black area highlighted, and from what I can see, it appears to be moulded into the centre console. Not sure if that helps or hinders you.
Name:	A8D2HandbrakeCover (Large).jpg
Old 31st January 2021, 02:58 PM
Maybe there's been a repair? Mine looks exactly like Sean's, even down to the repaired peg at the other end...…. (do they ALL break?)
Old 31st January 2021, 06:19 PM
First time I've ever removed it, but it appeared to be fully intact, with the duct tape acting more like padding.
Old 31st January 2021, 08:35 PM
Yes, that’s what we’re talking about. I’ll photograph my plastic piece tomorrow, but it’s definitely come adrift from the centre console.
