Old 9th January 2020, 01:02 PM
Default No Longer Wanted (single 20" D2 FE diamond cut alloy wheel)
Does anyone have a single 20" FE wheel for sale? The D2 size, not D3.
Ideally with a good diamond-cut face, not painted.
One of mine has some bad pothole damage and has been repaired once already so I'm looking at options.
Old 9th January 2020, 01:36 PM
I think Neil had a brand spanking new 20" FE for sale a while back. Perhaps try sending him a PM if he doesn't see this post.
Old 9th January 2020, 02:08 PM
I think Neil's was a D3 one which is 1/2" wider, but I'll check if he doesn't reply here.
Old 10th January 2020, 09:18 AM
The "Brand New" D3 one ended up being a D2 one, but has gone to TinTin now, but I still have a couple of FE D2 Spare Wheels at 8.5mm, need to check if they are diamond cut or not (I suspect not so may need doing)
Old 10th January 2020, 11:01 AM
Thanks Neil, let me know what you have.
The potential problem with refurbished/repainted ones is that underneath the coating they may well no longer be suitable for diamond cutting.
I've handed over my damaged wheel to a specialist repairer and await their opinion after taking the tyre off and examining it in detail.
My spare wheel (currently on the car) is "sort of" diamond cut and could potentially be "revitalised", so I have some options.
Old 16th January 2020, 04:55 PM
So, they have been busy and only just looked at it today.
Apparently the tyre is damaged too, so I'll need to get a new one. But the wheel is repairable.
Given the spare is a different design tyre (the slightly older MPSS) I'll probably buy a pair of new MPS4S's and retire whatever is the worst current tyre to be the spare.
That way I'll have two brand new and two fairly new MPS4S's on the road and a worn MPS4S as spare.
As for the wheels I'll see what the repaired one is like, I might consider having the spare diamond cut again and move the one with most cosmetic marks to be the spare.
At the end I will also probably have a part-worn 20" MPSS available. I got it originally from Adrian and have only added a handful of miles so it's still good for a spare at least. Will need to check the date code.
Meanwhile I'll dig out one of my winter wheels (haven't fitted them this year) to be the spare while all this shuffling takes place!
