Old 26th November 2018, 10:39 PM
I posted earlier from Plusnet, now from EE 4G.
Old 27th November 2018, 07:06 AM
Results
1. Yes, 2. No, 77. No, 81.No - Chrome Mobile on TalkTalk Broadband.
Old 27th November 2018, 07:26 AM
1: Yes, 2: No, 77: No, 81: No. FF on W7
Posts 77 and 81 appear to be the same?
Old 27th November 2018, 08:21 AM
Could I ask you to check each of the links above and report which ones have or have not any images. I came across this irregularity whilst reading someone else's write-up.
All working "normally" for me. W10, IE, PlusNet.
Note that "normally" means images do NOT always load the first time from clicking on a thumbnail, in fact quite often they don't and you just get a black window but with the next/previous controls visible. You have to try again sometimes 2 or 3 times. If there are a sequence I tend to click next, next, next until I go right round and on the 2nd pass they usually appear.
It's been like this for ages by the way, behaving today exactly as it has for a long while.
I've put this down to using IE which MS are slowly allowing to degrade.
Uploading images is always 100% reliable. And fully embedded images are OK too, it's just clicking on thumbnails that I often have a problem with.
Old 27th November 2018, 07:17 PM
Just checked and you're right. Despite the URLs being different, they are both showing the same post, number 81. I'm going to just copy and paste the links again to see if the same thing happens:
http://forum.a8parts.co.uk/showpost....4&postcount=77
http://forum.a8parts.co.uk/showpost....3&postcount=81
The first one shows the images, the second one doesn't.
NOTE: Have just tested the above links, and they work properly. I've also updated the links in the previous post, and also tested those to ensure they were working.
Last edited by steamship; 27th November 2018 at 07:21 PM. Reason: Added note at end
Old 27th November 2018, 07:28 PM
Ok I get the same - pics in the first post by Neeldub, nothing in the second one by Delboy.
Old 27th November 2018, 08:59 PM
Results
Steamship 1. Yes, 2. No, 77. Yes, 81.No - W10x64, Chrome/Firefox/Edge, Origin Broadband
tc4332 1. Yes, 2. No, 77. Yes, 81.No - W10x64, Firefox,Virgin Cable
Old 30th November 2018, 12:00 PM
Testing....
Old 30th November 2018, 12:02 PM
Testing Hi Res:
Old 30th November 2018, 12:11 PM
Thanks all for the debug.
Seems the prolonged power outage at the weekend caused the forum server to go down harder than I realised.
The immediate file system corruption should be fine now, so files should upload and store consistently. Feel free to check.
It seems like some photos may be missing - I'll pull those back from the backups over the weekend all being well
