Old 6th November 2020, 12:43 PM
V10ERR's Avatar
V10ERR V10ERR is offline
Default help needed
so today i notice that my parking sensors no longer work , all i get is a continus beep from the rear and nothing from the front , any pointers please
Audi S8 D3 2008 Facelift model in fantom black B & O, Auto, with Paddles, full leather, all heated seats, electric windows and mirrors,
MY MODS Limo black rear windows, Smoked out rear len's
tinted fronts, tinted plates .
Old 6th November 2020, 01:01 PM
When that happens on the D2, it’s because one or more of the sensors has failed. You can check which one with a VCDS diagnostic tool. You can buy D2 replacements on ebay and they’re not too difficult to fit. Ditto on an A6 that I did recently.
Old 6th November 2020, 01:28 PM
As 'The Laird' mentions, use something like VCDS to locate the faulty one. From what I've read previously, if one fails on the D3 it seems to disable the lot.
If you don't have VCDS, people have suggested switching the ignition to the ON position, put it in reverse, and then either place your finger on the end of each sensor in turn and you should feel it or place your ear next to it.
Old 6th November 2020, 07:14 PM
It’s does on the D2 as well, in my experience. And on the A6 that I sorted. You need access to a VCDS and then find a replacement on ebay. I can’t comment on how difficult/easy the job is on a D3, but it can’t be that tough.
Old 6th November 2020, 07:39 PM
homer simpson's Avatar
I know you looked into this, but definitely get yourself VCDS. These cars are pretty complicated and full of electrics. Well worth the money.
Old 6th November 2020, 08:07 PM
I had the same problem with mine a couple of years ago. VCDS miss diagnosed which one it was or I miss understood VCDS. ended up replacing the wrong one.
Second time round I used my ear. They are sonic sensors and so make a clicking noise like a dolphin. Although not completely silent, one was much quiter than the others.
I managed to change them both without removing the bumper cover but the inner one's are much harder to access than the outer ones. Or the other way round, I can't quite remember. Either way, one is harder than the other.
Audi S8 D2 2002 88k mls
Old 6th November 2020, 10:44 PM
Odd, as (thankfully) I've only ever had one fail on the D2 but the rest kept working. The rear D3 ones are real easy to replace, the front centre ones require a bumper off job.
Old 7th November 2020, 10:43 AM
johnny_quattro's Avatar
A cheaper alternative to VCDS is OBDEleven, which is an OBD dongle controlled by an app on your phone. It cost me about £45 from memory for both the app (+ licence) and the dongle. Mine picks up the fact that my inner left rear parking sensor is faulty. Which reminds me, I must get round to replacing it - it's only been a year or so now The OBDEleven unit has also been able to recode my gearbox, which I enthused about in another recent thread on 'autobox peculiarities'.
Last edited by johnny_quattro; 7th November 2020 at 10:44 AM. Reason: too many recents
