Old 16th February 2018, 08:29 PM
Norretal's Avatar
Norretal Norretal is offline
Congratulations on the S8 Sean, it's a beauty
Might I ask if you or Conquistador encountered any problems while removing the D3 centre console. I found the YouTube video I assume you're talking about and removed the ashtray holder, and the two screws behind it. That's where I stalled, the surround wouldn't budge, did you have to apply some force?
I only want to remove it to retrieve some coins that have slipped behind the cup holder lid and prevent it from opening fully. They can't be removed with it in situ without risk of scratching the alu or carbon finish.
Audi D3 S8 - 2007 - V10. B&O, Phantom Black, black and silver interior, and still completely standard with everything working as it should
Audi TT - 2015 - Ultra
Old 16th February 2018, 09:44 PM
Cheers. It's certainly attracting attention from family and DPD couriers.
With regards the centre console, I thought mine was stuck as well, compared to how easy the video shows it.
What I did was pry it out not from the very top, but from the sides where the ashtray used to be. I'm not sure if there's a clip or not behind it, but I applied a little bit of pressure from the inside of the console, just below the trim to be removed, whilst pulling gently upwards. That seemed to free it up. I then repeated the process on the other side, and that freed up the top of the trim. As mentioned in the video, just be careful as you pull it up past the dash.
I did manage to get out for a short run yesterday and discovered that I hadn't fitted the ashtray properly, as the cover would pop open when going over a bit of rough road. Something for me to check over the weekend.
Old 16th February 2018, 10:49 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
[quote=steamship;137924]Cheers. It's certainly attracting attention from family and DPD couriers.
...this is what happens when life gets busy and you disappear off a forum for a while!
Next time you're down in Belfast give me a shout, would like to see the new car Sean
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 17th February 2018, 07:50 AM
Norretal's Avatar
Thanks for the reply Sean, sounds like I just need to apply a bit more pressure when attempting to remove it. The right side did seem to be moving whereas the left side was stuck firm, I'll have a look and see how it's held in position later
I should have known the video was misleading, it simply couldn't be as easy as that
Thanks again
Old 17th February 2018, 08:47 AM
Remember in these videos the bloke doing it has had a dry run before videoing it. You have years of dried polish, spilt coffee and fizzy drinks in the cracks, plus the retaining clips.
Old 17th February 2018, 11:59 AM
Norretal's Avatar
How dare you, Ray?
I'll have you know it's immaculate in there, the ashtray is unused and only a thin layer of dust in evidence. It's a credit to its previous owners, including IT and roberto
I've got more time today, I'm off out to take a closer look and have another go...
Old 17th February 2018, 12:11 PM
Certainly can, although it's not very often I'm up in that direction.
His trim also seemed very flimsy when pulling it out and pushing it back in again, considering he was doing it with one hand.
Last edited by steamship; 17th February 2018 at 12:15 PM. Reason: Added response to Ray
Old 17th February 2018, 06:24 PM
Norretal's Avatar
All sorted within an hour of my last post, great advice fellas
Undo the screws as shown and in the video, place thumbs on gear lever surround and ease trim up with index fingers, it'll pop out of the first pair of retention clips. Ease the trim past the dashboard and the leverage will pop it out of the second pair (just adjacent to the front edge of the cup holder) Watch for the pegs pulling out the clips as you ease up as they fall into the void below. I picked mine out with long nosed pliers. The cup holder fastens onto the centre console with another four torx (same size as the previous three) and undoing these allowed me to remove the coinage that had annoyed me for ages.
Spent a while brushing out dust and debris, small vacuum cleaner completed the job, reassembled in minutes with an additional £2.30 in my pocket
Thanks Sean, apologies for the thread hijack
Old 17th February 2018, 10:01 PM
Can't complain about that! Cleaned part of the car, reduced it's weight a little by removing excess ballast and got paid for doing it as well.
Old 18th February 2018, 08:41 AM
SWMBO has called a postponement on my modification.
She says I have to stay indoors because I have a cold.
Can't be all bad, she just might collymoddle me for a bit.
