Cruise control stalk switches - dismantling
I have had (probably in common with many others) problems with my cruise control for ages. This is absolutely down to the switches on the stalk, specifically on the slider switch.
When I first got the car it didn't work at all. Following advice from others here I applied contact cleaner and vigorously exercised all the switches. Eventually it started working. The "set" button on the end works reliably (if pressed firmly) but the slider switch has always been problematic. Typically if you try to use it to increase the set speed it as often as not just turns cruise control off. So I just normally leave it in the "on position" at all times and increase speed with my right foot and then the "set" button. While investigating my brake pedal switch issue the other day I also had a look at the cruise control as it's in the same group of measuring blocks (Engine 66). I can see in VCDS that operating the slider switch will frequently generate an "off" code for a short time, so it is clearly faulty and ideally I'd like to try and fix it. Does anyone know how to take the end of the stalk apart to get at the switches, ideally without needing to remove it from the car? It looks as if the actual slider will probably just pop off, but I'm reluctant to do that unless someone knows that is safe and will reveal some screws or fixings relevant to getting inside.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
I have a duff one which I was contemplating taking apart for this exact investigation. Its sacrificial so it may come apart with the aid of the Dremel, but at least then we'll find out how it's put together
Cheers MJ, are you planning to do that sometime soon or want to pass/send it to me at some convenient time for me to have a look?
If it's part of the whole unit with the lights stalk presumably not easy to "pop in the post"? PS I think (hope) you've still got my sill plates somewhere safe.....
I can see them from here
I can split it from the wiper stalk so PM me your address and you can have at it |
It may mean removing the arm completely, but let's see how MJ fares with the Dremel. I've probably only used cruise control on mine a handful of times, but not that to attack it any more.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
Thanks Sean, MJ is sending her sacrificial one to me anyway so I'll document what I find in due course.
Never knew about the slider just set it and then reset it everytime
Audi S8 D2 #ronin - Cedar Green Abarth 500 Esseesse - Sold RS6 Avant Black - Stolen Mercedes Benz CLS 500 - Sold Corsa VXR Nurburgring - Sold RS6 Avant Grey - Sold Seat Leon Cupra R - Sold |
I only ever use mine where there are average speed cameras! It’s always been a bit temperamental and more bother than it’s worth most of the time, IMHO. Now, if we had any good long stretches of quiet motorway anywhere, that would be different.. But I do look forward to the autopsy!
I always assumed it was me doing something wrong why I could never increase speed using the stalk, but could easily decrease it. I have been doing the increase using throttle method and then (re)setting it. It never occurred to me that the stalk could be faulty.
I’m interested in what you find out Andrew.
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ) 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Ibis White |
