Old 9th April 2024, 03:46 PM
Lovelybus Lovelybus is offline
Default It's' all in the bushes? Hope so!
Hi, I think the resource is in here somewhere but I've not found it, so my apologies if I'm repeating but I'm at my wits end.
I have a 2001 S8 which I love, but I've been chasing a slight wobble on braking that's driving me crazy - feels like it's on the back end?
All Wheels balanced and aligned
All New tyres
New discs, pads hoses and calipers refurbed.
4 wheel alignment done.
I've been told that it could be lower arm bushes, but they are NLA for my D2.
Rumour is that there's an A6 that fits/
Or preferably, I'll get them all replaced. If one is gone, the other can't be far behind? Or any other suggestions?
would this work? Anyone tried them?
https://www.strongflex.eu/en/a8-d2-f..._diameter-18mm
any help would be so gratefully received - as it's my daily driver.
Old 9th April 2024, 07:32 PM
Firstly, welcome. If you're planning on staying around, pop along to the Introductions section and introduce yourself. It's also worth updating your profile so that we know where you're located, and add the car details to your signature line.
As for your issues, here's one suggestion I've seen mentioned before, especially since you had the callipers refurbished. The stainless steel pad guides are a tight fit, and depending on the refurb job, they might be sticking.
There's probably a lot more options, but at least you're searching in the right section of the forum. Remember to keep us updated if you resolve the issue.
Old 11th April 2024, 11:31 AM
Default Bushes
Thanks for this. Will fill in the intro stuff just now.
No - New spring clips fitted and ground down the edges of the pads so they don't stick.
Old 11th April 2024, 01:02 PM
Are we talking about the front or rear suspension?
Audi S8 D2 2002 88k mls
Old 15th April 2024, 02:06 PM
Default It's all in the bushes ?
Front feel ok, defibnitley feels like it's "behind me"
Old 16th April 2024, 05:15 AM
This may have some of the info you need.
https://forum.a8parts.co.uk/showthread.php?t=15086
