Old 2nd January 2015, 05:54 PM
Phil303 Phil303 is offline
Default Syncing temperatures
Is it possible to sync the drivers and passenger temperatures on a D2 S8; i.e. adjusting the driver side adjusts the passenger one at the same time?
Old 2nd January 2015, 06:01 PM
I'm sure I have done this but can't remember for the life of me what I did!
Old 2nd January 2015, 07:18 PM
Its there on the d3 but i dont think the d2 had sync mode.
Old 2nd January 2015, 07:31 PM
You could try pressing and holding the "Auto" button on the HVAC for 5 seconds or so as that works on many Audis to synch both sides
I'll try it on mine in the morning . . .
Old 3rd January 2015, 02:16 PM
I've tried that but no luck. I suspect it was a D3 onwards feature. First world problems eh?
Old 3rd January 2015, 02:43 PM
Sir WIll Sir WIll is offline
I could sync on my D3 but I cannot see anyway of doing it on the D2.
I am not sure how I am going to cope, do you think Bob Geldof will do a record for D2 owners and our suffering due to no seat heat syncing?
Old 3rd January 2015, 07:26 PM
As long as Chris Martin doesn't make an appearance I'd be happy if Geldof turned his attention from famines & Ebola and addressed the far more serious issue of fractionally mis-matched temps and the struggle to keep them even.
Old 3rd January 2015, 08:09 PM
Something I've been trying to find out myself. I use to do it on the '01 A4 I had, but the same trick doesn't work with the D2.
