Old 9th July 2016, 09:47 AM
Default Who's Online Gone
I noticed that the "who's online" facility has been removed. I always found it useful e.g. to find out if there was someone about who was likely to respond to my posts if I was waiting for an answer. I am sure that it was removed for a good reason but can the mods explain why?
Old 9th July 2016, 10:11 AM
The administrator has disabled Who's Online.
Not sure how accurate it was though.
http://forum.a8parts.co.uk/online.php
Old 9th July 2016, 01:05 PM
I don't think it's ever been switched on in my time on the forum? Only been able to see latest new member.
Old 9th July 2016, 01:14 PM
It has been available until relatively recently tho' i cant think when i last used it.
Old 11th July 2016, 08:45 PM
Not much escapes you lot does it?
I removed the whos online, as to be honest it rarely worked well. For the techies amongst us, it insists on doing a reverse look up of all the ip addresses, which usually times out, so it was all pointless and worked less reliably as we got more users on board.
Fearing the wrath of unhappy users, I did at the same time enable the feature that lets you see who is browsing the current forum, so same effect, sort of...
Old 11th July 2016, 08:47 PM
ta for the answer Ian.
Old 26th November 2016, 09:53 PM
where can we find that, probably me being thick again
Old 26th November 2016, 10:07 PM
It's at the bottom, below the 'quick reply' window... and works unless you're invisible!
Want to be invisible? Go into the 'User CP' and then click on 'Edit Options' down the left hand side. The first checkbox, if checked, allows you to become invisible.
Old 26th November 2016, 10:11 PM
cheers Sean, missed that completely
