Old 29th March 2018, 06:56 PM
Default Anyone Changed Brake Fluid & Bled With VCDS
Pretty much as the title implies. The car is coming up for its MOT in a few weeks time, and in the process of doing other stuff, I was thinking of replacing the brake fluid, as it was last changed about four years ago.
Has anyone done this themselves, and if so, how? There is an option within VCDS to bleed the brakes, but I've never used it, so not sure what it involves.
Just wondering how much brake fluid I'll need to completely flush out the existing stuff.
Old 29th March 2018, 09:05 PM
Regulus Regulus is offline
I haven't done this myself. But as far as I can discover.
http://www.audipages.com/Tech_Articl...rakebleed.html seems to suggest 1 liter.
According to my workshop manual, see attached file
Name:	brake fuel change.png
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Old 29th March 2018, 09:38 PM
Yeah a litre should do it.
VCDS is only needed to cycle the ESP pump if the system has been opened in that area or drained. For a straight fluid change it doesn't need to be done. The sequence is different for cars with ESP though:
1 - rear left
2 - front right
3 - rear right
4 - front left
Old 30th March 2018, 12:16 PM
Thanks for that link. Just read it and it seems reasonably easy.
1 - rear left
2 - front right
3 - rear right
4 - front left
The link that Regulus gave mentions doing the front left first because it has the shortest run. If I just substitute the order you've given instead, that should be okay? From what it says, it just seems to be the quickest way to drain the reservoir to the lowest level.
Old 30th March 2018, 12:39 PM
In terms of draining the reservoir, the length of the pipe doesn't matter - you've got the same volume of fluid going through it whether its an inch long or ten feet
The shortest first logic to bleed the system makes sense because any air from the master cylinder or ABS module will come out sooner. Elsawin does give the two specific procedures though - with and without ESP.
Personally I think it makes no difference either way for a fluid change
Old 30th March 2018, 12:48 PM
Great. I shall delve into that as well for instructions.
Old 30th March 2018, 01:32 PM
You might also invest in one of these. Makes it all so easy.
www.toolstation.com/shop/p82378?r=googleshopping&rr=marin&utm_source=google shopping&utm_medium=feed&utm_campaign=googleshoppi ngfeed&gclid=CjwKCAjwwPfVBRBiEiwAdkM0HWaBrZq_vk_5z 6YnW5ItnP0DpUIJgGZjRYDDeoDnntJszSWd4YNLyRoC1J4QAvD _BwE
Old 30th March 2018, 07:09 PM
Beat you to it Mike. I've already ordered the bleeder
Old 30th March 2018, 07:25 PM
You'll need 2 bar pressure to push the fluid through the ABS unit.
Old 1st April 2018, 12:04 AM
27litres's Avatar
27litres 27litres is offline
1 - rear left
2 - front right
3 - rear right
4 - front left
Any insight into why this order? Diagonally opposites... kind of makes sense.
I've always been told to bleed furthest to closest to the reservoir (although with the location of the ABS pump, front left and rear left probably have shorter pipe runs than front right and rear right respectively)
The Audipages procedure uses a pressure bleeder and states using 10psi. Will the reservoir support 30psi (or 29.4 )?
Or does 2 bar mean absolute (so 1 bar above atmosphere)!
I bought a Mityvac vacuum bleeder (MV8000) to attack it from the caliper end. There are various versions of these pumps around, but Mityvac have a good trade reputation.
I paid about US$55 shipped from Amazon (click here). Just checked Amazon UK for the same item - £50, what a rip off!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
