Old 21st July 2021, 10:45 AM
Johnmed's Avatar
Johnmed Johnmed is offline
Default MMI ECU replacement
Hi all. My MMI Multimedia Interface Control Module ECU has been on the blink for a few months now and I’ve tried, to no avail, to find a replacement. Our sponsors have these HW items but not with the correct SW number.
HW 40035729
SW number 4E0910769P
I was wondering if anyone knew if the SW number has to be exactly the same, as none I’ve seen online are, some end in H or Q for example. I’m not sure if either or neither of these would work.
All the best. John
2007 Mini Cooper S R56
Old 21st July 2021, 12:44 PM
The only thing I can find is that part number 4E0910769P was replaced by part number 4E0910769PX. Can't find anything on what each variant has/does. There appears to have been several variants of this module in the D3, all of which have been superseded over the years to 4E0910769PX or 4E0910769QX.
It might be worth having a chat with Maria or one of the other team at A8parts, and see if they're willing to refund you if you get one from them and it doesn't work.
Old 21st July 2021, 01:28 PM
Johnmed's Avatar
Cheers mate. Some more info to go on there. I did email our sponsors again, and Maria got straight back and they’ve got one. But it’s £250. I’m a tight wad, and don’t use the car so much just now; mostly it’s ok. So I’m not convinced replacing it will be the cure all.
So I’ll keep on the look out I think, cos online they seem to be cheaper. May even take a punt on one that’s SW is very similar.
Old 23rd July 2021, 05:13 PM
ulfilias ulfilias is offline
Hi There,
I'm *STRUGGLING* with my MMI as per http://forum.a8parts.co.uk/showthread.php?t=16341
I thought it was the gateway, coding or some such, but it has taken me down QUITE a rabbit hole.
I just ordered up one from ebay for about £50, which is
HW - 4E0035729A - You have 400 at the front 4E0 is typically the d3 audi.
SW - 4E0 910 732
Looking at reversing camera retrofits they are quite often swapped out for the A model, which has a green FBAS connector on it - Mine was already an A
Mine had SW 4E0 910 730
However a lot on ebay are A6's with 4F0 software but the same model number. How convertible they are i'm not sure.
I *MAY* hit component protection which is a dealer job or trying to copy a chip across - The programmer is cheap, so i've one on order
https://www.dognmonkey.com/audi/how-...ection-cp.html
I'd also add i'm VERY new to this MMI journey and i've read a lot, my head is spinning a bit, so please check stuff first to verify for yourself!
Current :
Previous :
Also :
Old 23rd July 2021, 05:30 PM
Johnmed's Avatar
Hi mate. I’ve ordered one from eBay too, and fear I may be descending down the very same EPROM, component protection rabbit hole!
The thing is I’ve used my car lots the last few days and it hasn’t put a foot wrong. Which leads me to think the cause could need more investigation. (I’m having audio drop outs) I’ve bought this, see attachment. Purportedly from an A8 with the FBAS.
I just don’t want to spend time and money and make it worse and then be stuck needing a trip to the stealers with a CP issue.
Old 4th August 2021, 02:01 PM
Originally Posted by ulfilias View Post
Hi There,
SW - 4E0 910 732
Well.....My issue was the buttons. Changed those and my MMI sprung back into life
However since i had the "new" head unit, i though i'd pop it in.....And well no music, speaker icon with a line through. The NAV voice did however work, so i'm guessing Component protection. And yes, a quick VCDS scan did show CP active!
I *THINK* there may be a different software version on the "new" head unit as i'm on 5570 looking at my old VCDS scans - I checked the coding and they WERE the same. Unsure if updating the software would unlock the CP or not.....But i've got the chip reader and i'm now curious, so will dump my rom and then transfer it to the new box and we'll see
Current :
Previous :
Also :
Old 4th August 2021, 03:12 PM
Johnmed's Avatar
Eek. I admire your perseverance. The more I thought about the issue the less I’ve been inclined to do anything about it. All I have is a click and a few seconds of silence.
I’ve got the ECU, but can’t be bothered with CP and S/W incompatibilities so it’s on the shelf for now.
I hope you get yours fixed 100%.
Old 4th August 2021, 05:17 PM
Updating the software won't remove CP. You need someone who has ODIS and a genuine Geko certificate to remove it.
Old 5th August 2021, 10:21 AM
HPsauce HPsauce is online now
Reminds me of an issue many many years ago with a minicomputer system that was satellite (one of many) to a huge mainframe.
It was misbehaving and the engineers kept stripping it down and replacing various components as their diagnostics were not definitive, with no luck.
In the end I (onsite project manager) recall a conversation with the chief engineer who said "We've replaced every F******** part of this thing except the tin box and the console keypad!"
At which point I saw him have a "light bulb moment". And a few minutes later, having extracted a keypad from another system it was up and working.
