Old 22nd January 2024, 11:22 AM
donp38 donp38 is offline
Default Thermostat D2 FL S8
Hi All.
This is on a 2002 FL S8
Is the thermostat a timing belt off job?
My local; specialist did the cambelt + last year and didn't do the thermostat.
Now it needs doing and advised they need to take the cambelt off to do it..
I thought I had instructed them to change the stat, but cannot find any emails to prove....anyway what do to?
Please advise.
Old 22nd January 2024, 01:17 PM
From the work I've done on the car, I would say a definite yes, but I do recall seeing a post somewhere where they said they could do it without removing it, by just prising it forward, which I reckon would be very tight and need multiple hands.
If you look at image 688, I've highlighted where the thermostat is, behind that metal pipework. Image 423 shows what's in front of 688, and image 680 shows what's in front of 423. Take into account that I also had the entire front end off the car, but I needed to do that. This is a 3.7 engine, but the 4.2 has a very similar layout.
EDIT: Found the link, with video, but the engine is out of the car!
https://www.audiworld.com/forums/a8-...-belt-2909229/
Name:	IMG_20230406_190426_688 (Custom).jpg
ID:	30121   Click image for larger version
Name:	IMG_20230407_122428_423 (Custom).jpg
ID:	30122   Click image for larger version
Name:	IMG_20230407_150852_680 (Custom).jpg
Old 22nd January 2024, 05:39 PM
Many thanks.
In all fairness to the garage.
They have agreed to do the stat at just a few hrs labour.
the rest they will stand.
Can we still get Audi thermostats?
Old 22nd January 2024, 05:54 PM
The part number is 077121113C, superseded by 077121113D, and according to ETKA, is still available.
Old 23rd January 2024, 04:09 PM
Great.
I will advise the garage.
They did advise they wanted to use OEM Audi part.
I will definitely not be supplying the thermostat!!
Old 24th January 2024, 06:07 AM
Did they change the water pump? I thought that the water pump and thermostat changes were ‘standard procedure’ when doing the cam belt.
