Need help with ABS problem. 4.2 -03
Hi there. Recently bought this car and boy, what have I gotten myself into. lol. Anyway, have a bunch fault codes but the reason for this post is the red brake warning light and the parking brake light that appeared on my dash. Parking brake seems to work though. Here's the scan:
Tuesday,31,December,2019,14:33:30:02198 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4 Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: WAUZZZ4E53N002404 License Plate: Chassis Type: 4E (4E0) Scan: 01 02 03 05 07 08 09 15 16 17 18 19 1E 25 28 34 37 38 42 46 47 4F 52 53 55 56 57 61 62 69 72 76 77 VIN: WAUZZZ4E53N002404 Mileage: 275780km-171361miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 1010 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 69-Trailer -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: 077-910-560-BFM.clb Part No SW: 4E0 910 560 HW: 4E0 907 560 Component: 4.2L V8/5V G 0080 Revision: 00000000 Serial number: AUX3Z0B9102748 Coding: 0011773 Shop #: WSC 02353 785 00200 VCID: 5EE56298BC371C979BB-800A 5 Faults Found: 17981 - Left Engine Mount Solenoid Valve (N144) P1573 - 004 - Open Circuit 18284 - Valve for Torque Support Mount P1876 - 004 - Open Circuit - Intermittent 18057 - Powertrain Data Bus P1649 - 008 - Missing Message from ABS Controller - Intermittent 18057 - Powertrain Data Bus P1649 - 008 - Missing Message from ABS Controller - Intermittent 18057 - Powertrain Data Bus P1649 - 008 - Missing Message from ABS Controller - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 HW: 09E 927 156 Component: AG6 09E 4,2L5V RdW 0100 Coding: 0000001 Shop #: WSC 22829 142 16354 VCID: 5F9B5F9CBB3D159F90D-800A 1 Fault Found: 18259 - Powertrain Data Bus P1851 - 000 - Missing Message from ABS Controller - Intermittent Freeze Frame: RPM: 1280 /min RPM: 1312 /min RPM: 1152 /min (no units): 36.0 (no units): 22.0 Temperature: 55.0°C T.B. Angle: 0.8° Voltage: 13.68 V ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 E Component: ESP 5.7 allrad H29 0400 Coding: 0008597 Shop #: WSC 00046 000 00000 VCID: 211F1964CDC9636FE69-8074 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H01 0070 Revision: 00702901 Serial number: AUX3Z0B9102748 Coding: 0262144 Shop #: WSC 02311 785 00200 VCID: 58E97480DE13E2A7D17-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.clb Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300B4037515501 Coding: 0000002 Shop #: WSC 00000 000 00000 VCID: 3A2DCE08405F10B7C73-806E Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0040 Subsystem 2 - Serial number: 00000000023587 Subsystem 3 - Serial number: 0131.10.060000000100010029˙ Subsystem 4 - Serial number: 010029˙ 2 Faults Found: 02257 - Remote Control Receiver 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 5 Fault Frequency: 1 Reset counter: 35 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:40:38 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 27 Reset counter: 41 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:54:44 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 011 0130 Revision: 00000007 Serial number: 00000000004422 Coding: 0069843 Shop #: WSC 02311 785 00200 VCID: 5AED6E88A01FF0B7E73-800E 11 Faults Found: 00711 - Left Footwell Flap Positioning Motor (V108) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 7 Reset counter: 75 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:40:46 Freeze Frame: Voltage: 11.60 V Temperature: 19.0°C (no units): 80.0 (no units): 98.0 Temperature: -85.0°C 01274 - Air Flow Flap Positioning Motor (V71) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 14 Reset counter: 80 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:40:47 Freeze Frame: Voltage: 11.60 V Temperature: 19.0°C (no units): 80.0 (no units): 98.0 Temperature: -85.0°C 01592 - Air Quality Sensor (G238) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 2 Reset counter: 41 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:40:50 Freeze Frame: Temperature: 23.0°C 01087 - Basic Setting Not Performed 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 227 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 01:30:31 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 5 Reset counter: 39 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:40:51 Freeze Frame: Voltage: 11.60 V 00716 - Air recirculation Flap Positioning Motor (V113) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 50 Reset counter: 80 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:40:55 Freeze Frame: Voltage: 11.60 V Temperature: 18.0°C (no units): 75.0 (no units): 98.0 Temperature: -85.0°C 00819 - High Pressure Sensor (G65) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 80 Mileage: 275558 km Time Indication: 0 Date: 2019.12.28 Time: 22:03:18 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 18 Reset counter: 80 Mileage: 275558 km Time Indication: 0 Date: 2019.12.28 Time: 22:03:22 Freeze Frame: Voltage: 14.20 V 00727 - Potentiometer in Positioning Motor for Defrost Flap (G135) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 9 Reset counter: 80 Mileage: 275558 km Time Indication: 0 Date: 2019.12.28 Time: 22:03:24 Freeze Frame: Voltage: 14.10 V (no units): 131.0 (no units): 255.0 00710 - Defroster Flap Positioning Motor (V107) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 15 Reset counter: 76 Mileage: 275584 km Time Indication: 0 Date: 2019.12.29 Time: 18:24:52 Freeze Frame: Voltage: 14.20 V Temperature: 16.0°C (no units): 70.0 (no units): 89.0 Temperature: -95.0°C Raw, Form. N/A: 000 000 000 00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 80 Mileage: 275782 km Time Indication: 0 Date: 2019.12.31 Time: 14:08:53 Freeze Frame: Voltage: 14.10 V (no units): 1.0 (no units): 0.0 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.clb Part No SW: 4E0 910 279 A HW: 4E0 907 279 A Component: ILM Fahrer H11 0060 Coding: 0011012 Shop #: WSC 80248 790 00005 VCID: 26150A78A4E7845793B-8072 Subsystem 1 - Part No: 4E1 910 113 Component: Wischer WWS D3 H30 0310 Coding: 00000030 Shop #: WSC 80248 2 Faults Found: 01496 - Bulb for Fog-Lamps; Left (L22) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 41 Mileage: 275789 km Time Indication: 0 Date: 2019.12.31 Time: 14:30:24 01500 - Bulb for Fog-Lamps; Right (L23) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 41 Mileage: 275789 km Time Indication: 0 Date: 2019.12.31 Time: 14:30:24 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 Component: Airbag 8.4E+ H08 0840 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 6393536C9755317FB45-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H08 0020 Coding: 0012141 Shop #: WSC 02311 785 00200 VCID: 65974D7499614F4F5A1-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H06 0050 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 900 E Component: KOMBIINSTR. VDO H33 0020 Revision: 5 992703 Serial number: AUDID3B9003509 Coding: 0000103 Shop #: WSC 80248 790 00005 VCID: 5CE16890AA2B0E87F5F-8008 No fault code found. ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 HW: 4E0 265 081 Component: Heizgeraet H06 0280 Revision: 0000000E Serial number: 00000009001484 Shop #: WSC 00000 000 00000 VCID: 59EF7184A519FBAFEE9-800C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4E0-910-468.clb Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H06 0070 Revision: 06 Serial number: 0000302A1609FC Coding: FDFE7FC62B3504 Shop #: WSC 80248 790 00005 VCID: 65974D7499614F4F5A1-8030 2 Faults Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 20 Reset counter: 41 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:41:17 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 81 Mileage: 275747 km Time Indication: 0 Date: 2019.12.31 Time: 11:34:28 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 Component: CD-Changer H43 0470 Serial number: AUZ5ZBC1011215 Shop #: WSC 00000 000 00000 VCID: 1C612890EAAB4E8735F-8048 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H01 0070 Revision: 00702901 Serial number: AUX3Z0B9102748 Coding: 0262144 Shop #: WSC 02311 785 00200 VCID: 58E97480DE13E2A7D17-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 A Component: KLIMA-STG. FOND 011 0100 Revision: 00000040 Serial number: 00000000001645! Shop #: WSC 00000 000 00000 VCID: 619F59648D49236FA69-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.clb Part No SW: 4E0 910 553 C HW: 4E0 907 553 C Component: LUFTFDR.-CDC H03 4190 Coding: 0015500 Shop #: WSC 00046 000 00000 VCID: 2313136CD7D5717FF45-8076 3 Faults Found: 01437 - Control Position not Learned 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 11100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 35 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:41:20 00776 - Level Control System Sensor; Left Front (G78) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 11101100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 41 Mileage: 0 km Time Indication: 0 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 81 Mileage: 275747 km Time Indication: 0 Date: 2019.12.31 Time: 11:34:28 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H41 1060 Revision: 00000000 Serial number: 305JL027508720 Shop #: WSC 02313 785 00200 VCID: 3B23CB0C4F6529BFDC5-806E 4 Faults Found: 02261 - Data Medium 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 7 Fault Frequency: 21 Reset counter: 41 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:41:27 Freeze Frame: Hex Value: 0x5E0B Hex Value: 0x5B81 Hex Value: 0x0000 Hex Value: 0x0010 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 3 Reset counter: 81 Mileage: 275747 km Time Indication: 0 Date: 2019.12.31 Time: 11:34:33 Freeze Frame: Bin. Bits: 1100 03183 - Data Media not Compatible 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 152 Reset counter: 41 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:41:27 Freeze Frame: Hex Value: 0x5E0B Hex Value: 0x5BF9 Hex Value: 0x0000 Hex Value: 0x0000 02927 - DVD Read Error 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 69 Reset counter: 81 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:54:48 Freeze Frame: Hex Value: 0x5E0B Hex Value: 0x5BE7 Hex Value: 0x0401 Hex Value: 0x0204 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H01 0090 Serial number: 00000331000171 Coding: 0003734 Shop #: WSC 28100 141 17409 VCID: 1D672594F1B1478FC21-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E1 959 801 Component: Türsteuer.FS BRM004 0060 Coding: 0002848 Shop #: WSC 80248 790 00005 VCID: 5EE56298BC371C979BB-800A No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H03 0030 Revision: 00300003 Serial number: W040310240183 Coding: 0000600 Shop #: WSC 28100 141 17409 VCID: 270B077CA3ED9D5FA8D-8072 Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H01 0020 3 Faults Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 41 Mileage: 245937 km Time Indication: 0 Date: 2015.12.07 Time: 08:50:12 01504 - Bulb for License-Plate Light (X) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 81 Mileage: 275727 km Time Indication: 0 Date: 2019.12.31 Time: 10:39:11 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 81 Mileage: 275747 km Time Indication: 0 Date: 2019.12.31 Time: 11:34:29 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H12 0460 Revision: PROD_01O Serial number: 00000000096737 Coding: 0000026 Shop #: WSC 02353 785 00200 VCID: 2A0DFE48B0FFA037B73-807E 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 3 Reset counter: 81 Mileage: 275747 km Time Indication: 0 Date: 2019.12.31 Time: 11:34:29 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000038207 Coding: 0010101 Shop #: WSC 22829 142 16354 VCID: 1E652298FCB75C97DBB-804A 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 81 Mileage: 262136 km Time Indication: 0 Date: 2063.15.31 Time: 16:00:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E1 959 802 Component: Türsteuer.BF BRM004 0060 Coding: 0002848 Shop #: WSC 80248 790 00005 VCID: 5EE56298BC371C979BB-800A 2 Faults Found: 01482 - Motors for Central Locking 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 2 Fault Frequency: 2 Reset counter: 78 Mileage: 275616 km Time Indication: 0 Date: 2019.12.30 Time: 06:42:12 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 14 Reset counter: 81 Mileage: 275760 km Time Indication: 0 Date: 2019.12.31 Time: 13:31:36 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0000531 Shop #: WSC 80248 790 00005 VCID: 1F1B1F9CFBBD559FD0D-804A 2 Faults Found: 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 10 Reset counter: 81 Mileage: 275744 km Time Indication: 0 Date: 2019.12.31 Time: 11:34:47 Freeze Frame: Voltage: 13.56 V Count: 236 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 81 Mileage: 275744 km Time Indication: 0 Date: 2019.12.31 Time: 11:34:28 Freeze Frame: Voltage: 13.56 V Count: 242 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: AFS 1.Stufe H01 0020 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 80248 790 00005 VCID: 629D5668884F3877BF3-8036 3 Faults Found: 01539 - Headlights Not Adjusted 005 - No or Incorrect Basic Setting / Adaptation - MIL ON Freeze Frame: Fault Status: 11100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 35 Mileage: 275560 km Time Indication: 0 Date: 2019.12.28 Time: 21:42:05 01310 - Level Control System Control Module (J197) 008 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 35 Mileage: 275560 km Time Indication: 0 Date: 2019.12.28 Time: 21:42:05 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 255 Reset counter: 81 Mileage: 275752 km Time Indication: 0 Date: 2019.12.31 Time: 11:34:28 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 L Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 388AS067509324 Coding: 0000001 Shop #: WSC 31414 790 00001 VCID: 313FE9249D29D3EF769-8064 1 Fault Found: 00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 29 Reset counter: 40 Mileage: 271544 km Time Indication: 0 Date: 2002.09.14 Time: 20:24:58 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 E HW: 4E0 919 148 Component: R0078 TVhybridT 0470 Revision: R0H06000 Serial number: 76300800716502 Coding: 0000302 Shop #: WSC 31414 790 00001 VCID: 25170D74D9E18F4F9A1-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 B HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0240 Revision: 00000000 Serial number: 00000000002487 Shop #: WSC 22829 142 13099 VCID: 1F1B1F9CFBBD559FD0D-804A Subsystem 1 - Part No: 000 915 105 AK Component: von VA0 0404050245 Coding: 303030393135313035414B56413030343034303530323435 Shop #: WSC 80248 790 00005 1 Fault Found: 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 2 Reset counter: 78 Mileage: 275558 km Time Indication: 0 Date: 2019.12.29 Time: 04:43:54 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM004 0060 Coding: 0003872 Shop #: WSC 02311 785 00200 VCID: 5DE76594B131078F821-8008 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 14 Reset counter: 81 Mileage: 275760 km Time Indication: 0 Date: 2019.12.31 Time: 13:31:36 ------------------------------------------------------------------------------- Address 69: Trailer Labels: None Part No HW: 4E VCID: 55F77DB4C901DFCFCA1-8000 Subsystem 1 - Part No: 4E0 Component: Shop #: WSC 65536 001 394790 1 Fault Found: 00526 - Brake Light Switch (F) 008 - Implausible Signal Freeze Frame: Fault Status: 00000000 Fault Priority: 0 Fault Frequency: 20 Reset counter: 82 Mileage: 93185 km Time Indication: 0 Date: 2000.00.20 Time: 00:16:02 Freeze Frame: Raw, Index/Key Err.: 252 000 000 Chan. Number: 45 Resistance: 6 ohms Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM004 0060 Coding: 0003872 Shop #: WSC 02311 785 00200 VCID: 5DE76594B131078F821-8008 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 HW: 4E0 919 283 A Component: Parkhilfe 8-Kan H07 0030 Coding: 0011008 Shop #: WSC 02353 785 00200 VCID: 60995C6086432A67A97-8034 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 3 Reset counter: 81 Mileage: 275747 km Time Indication: 0 Date: 2019.12.31 Time: 11:34:29 ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End----------(Elapsed Time: 02:24, VBatt start/end: 11.8V/12.0V)----------- The ABS control module error seems to show up everywhere. I just don't know where to start. Can anyone make any sense of this? Also, the ABS unit/pump keeps going and going after the car is shut off. Have to disconnect it to make it stop. Is it the control module that is shot? Relay(is that J329?)? Wiring? Can a bad module be responsible for some of the other fault codes I have? I've cleared the codes but they come back Last edited by classexa; 7th January 2020 at 12:58 PM. |
A couple of things before delving into the VCDS scan.
Since you're a new member, pop along to the Introductions section and introduce yourself to everyone. We're a friendly lot, and we don't have many rules, but we do like to see other members cars, so photos are welcome. Also, to make things easier down the line when looking for assistance, amend your profile setup to include car details and a rough location. The car details may make it easier to help diagnose issues, and the location is just so if you need help, someone may just be round the corner, or maybe just to meet up for a chat. Now, the scan. You make the comment about the ABS errors occurring in several modules, and it is remarkable how these cars work, and how they are all seemingly interconnected, so yes, an error may appear in what seems like an odd location/module. The majority of the errors appear around the same date, but there some other odd anomalies around dates and other data. You have one error with a date of 2000, yet the car is an '03 model. You also have a error with a temperature reading of -85 degrees, which is somewhat chilly! Since you have VCDS, what I'd suggest you do is always save a copy of the scan, as it may be useful later on. The next thing to do is clear all the codes (some codes may not clear is they are classed as a 'permanent' fault, and will only clear by replacing/repairing the offending item). Once you've done that, take the car for a drive, and then scan the car again, and you should hopefully have fewer errors second time around. Error codes can occur because the battery was disconnected at some time, and this could account for some of them. Post up what's left, and then we can go from there. Regarding the ABS specific issue, and the pump continuing to run, one suggestion I came across was a faulty relay (which you hint at). I can identify the relevant relay on the D2 platform, but at the moment can't find the equivalent of the D3 platform.
Hi. Thanks for the reply. Will definitely pop in to introduce myself. I do have a copy of the scan(before and after) and I've cleared the codes and gone for a drive. Did a scan again and these came back
The only relay I can find that is connected to the ABS unit is J329. It's the terminal 15 relay. Would a faulty realy cause all these ABS module codes though? This is the first scan. Then I drove for about 100 miles and did a scan again(the one in the 1st post): Code:
Saturday,28,December,2019,21:32:15:02198 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4 Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: WAUZZZ4E53N002404 License Plate: Chassis Type: 4E (4E0) Scan: 01 02 03 05 07 08 09 15 16 17 18 19 1E 25 28 34 37 38 42 46 47 4F 52 53 55 56 57 61 62 69 72 76 77 VIN: WAUZZZ4E53N002404 Mileage: 275550km-171218miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Malfunction 0010 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 1010 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: Malfunction 0010 25-Immobilizer -- Status: Malfunction 0010 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: Malfunction 0010 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 69-Trailer -- Status: Malfunction 1010 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: 077-910-560-BFM.clb Part No SW: 4E0 910 560 HW: 4E0 907 560 Component: 4.2L V8/5V G 0080 Revision: 00000000 Serial number: AUX3Z0B9102748 Coding: 0011773 Shop #: WSC 02353 785 00200 VCID: 5EE56298BC371C979BB-800A 6 Faults Found: 17981 - Left Engine Mount Solenoid Valve (N144) P1573 - 004 - Open Circuit 18010 - Power Supply Terminal 30 P1602 - 002 - Voltage too Low - Intermittent 16825 - EVAP Emission Control Sys P0441 - 002 - Incorrect Flow - Intermittent 18284 - Valve for Torque Support Mount P1876 - 004 - Open Circuit - Intermittent 17538 - Fuel Trim; Bank 2 (Mult) P1130 - 001 - System too Lean - Intermittent 17536 - Fuel Trim; Bank 1 (Mult) P1128 - 001 - System too Lean - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 HW: 09E 927 156 Component: AG6 09E 4,2L5V RdW 0100 Coding: 0000001 Shop #: WSC 22829 142 16354 VCID: 5F9B5F9CBB3D159F90D-800A 2 Faults Found: 18005 - Powertrain Databus P1597 - 000 - Missing Message from Level Control System (J197) - Intermittent Freeze Frame: RPM: 1376 /min RPM: 1312 /min RPM: 0 /min (no units): 25.0 (no units): 32.0 Temperature: 26.0°C T.B. Angle: 0.0° Voltage: 10.72 V 18290 - Powertrain Data Bus P1882 - 000 - Missing Message from Electric Parking Brake Controller - Intermittent Freeze Frame: RPM: 1376 /min RPM: 1312 /min RPM: 0 /min (no units): 25.0 (no units): 32.0 Temperature: 26.0°C T.B. Angle: 0.0° Voltage: 10.72 V ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 E Component: ESP 5.7 allrad H29 0400 Coding: 0008597 Shop #: WSC 00046 000 00000 VCID: 211F1964CDC9636FE69-8074 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H01 0070 Revision: 00702901 Serial number: AUX3Z0B9102748 Coding: 0262144 Shop #: WSC 02311 785 00200 VCID: 58E97480DE13E2A7D17-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 1 Fault Found: 00668 - Supply Voltage Terminal 30 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 0 Reset counter: 74 Mileage: 275248 km Time Indication: 0 Date: 2019.12.26 Time: 05:17:56 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.clb Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300B4037515501 Coding: 0000002 Shop #: WSC 00000 000 00000 VCID: 3A2DCE08405F10B7C73-806E Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0040 Subsystem 2 - Serial number: 00000000023587 Subsystem 3 - Serial number: 0131.10.060000000100010029˙ Subsystem 4 - Serial number: 010029˙ 10 Faults Found: 02257 - Remote Control Receiver 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 5 Fault Frequency: 1 Reset counter: 232 Mileage: 271758 km Time Indication: 0 Date: 2002.09.14 Time: 01:42:27 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 89 Reset counter: 75 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 00:55:09 02244 - Button in Control Head is Stuck 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 52 Mileage: 273790 km Time Indication: 0 Date: 2002.09.16 Time: 18:56:46 Freeze Frame: Bin. Bits: 00000000 Bin. Bits: 0000001 Bin. Bits: 000 01327 - Control Module for Parking Aid (J446) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 51 Mileage: 271548 km Time Indication: 0 Date: 2002.09.13 Time: 00:14:00 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 3 Reset counter: 51 Mileage: 273775 km Time Indication: 0 Date: 2019.11.27 Time: 08:20:48 Freeze Frame: Bin. Bits: 01 01310 - Level Control System Control Module (J197) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 51 Mileage: 273776 km Time Indication: 0 Date: 2019.11.27 Time: 08:24:47 02103 - Control Module 2 for Vehicle Electrical System (J520) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 51 Mileage: 273775 km Time Indication: 0 Date: 2019.11.27 Time: 08:21:17 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 6 Reset counter: 40 Time Indication: 15 00658 - Control Head 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 40 Mileage: 271546 km Time Indication: 0 Date: 2002.11.27 Time: 09:30:08 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 74 Time Indication: 15 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 011 0130 Revision: 00000007 Serial number: 00000000004422 Coding: 0069843 Shop #: WSC 02311 785 00200 VCID: 5AED6E88A01FF0B7E73-800E 17 Faults Found: 01592 - Air Quality Sensor (G238) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 14 Reset counter: 35 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 00:30:03 Freeze Frame: Temperature: 17.0°C 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 31 Reset counter: 74 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 00:30:03 Freeze Frame: Voltage: 12.00 V 00716 - Air recirculation Flap Positioning Motor (V113) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 3 Fault Frequency: 254 Reset counter: 35 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 00:30:16 Freeze Frame: Voltage: 12.00 V Temperature: 18.0°C (no units): 78.0 (no units): 72.0 Temperature: -84.0°C 01087 - Basic Setting Not Performed 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 227 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 01:30:31 00710 - Defroster Flap Positioning Motor (V107) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 225 Reset counter: 47 Mileage: 271731 km Time Indication: 0 Date: 2002.09.13 Time: 09:31:17 Freeze Frame: Voltage: 14.10 V Temperature: 13.0°C (no units): 70.0 (no units): 77.0 Temperature: -91.0°C Raw, Form. N/A: 000 000 000 00020 - Motor for Blocking Flap; Defrost and Body Vents; Right (V199) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 39 Reset counter: 71 Mileage: 272173 km Time Indication: 0 Date: 2019.10.18 Time: 13:46:48 Freeze Frame: Voltage: 13.70 V Temperature: 12.0°C (no units): 70.0 (no units): 88.0 Temperature: -89.0°C 00021 - Motor for Blocking Flap; Defrost and Body Vents; Left (V200) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 15 Reset counter: 74 Mileage: 273857 km Time Indication: 0 Date: 2019.12.07 Time: 15:45:15 Freeze Frame: Voltage: 13.90 V Temperature: 13.0°C (no units): 75.0 (no units): 88.0 Temperature: -95.0°C 00711 - Left Footwell Flap Positioning Motor (V108) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 3 Fault Frequency: 83 Reset counter: 35 Mileage: 271544 km Time Indication: 0 Date: 2002.09.14 Time: 13:27:28 Freeze Frame: Voltage: 13.20 V Temperature: 14.0°C (no units): 80.0 (no units): 76.0 Temperature: -85.0°C 00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 22 Reset counter: 73 Mileage: 271544 km Time Indication: 0 Date: 2002.09.17 Time: 12:01:40 Freeze Frame: Voltage: 13.50 V (no units): 1.0 (no units): 0.0 01274 - Air Flow Flap Positioning Motor (V71) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 3 Fault Frequency: 75 Reset counter: 35 Mileage: 271544 km Time Indication: 0 Date: 2002.09.17 Time: 12:02:08 Freeze Frame: Voltage: 13.70 V Temperature: 4.0°C (no units): 75.0 (no units): 93.0 Temperature: -97.0°C 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 19 Reset counter: 74 Mileage: 271544 km Time Indication: 0 Date: 2002.09.17 Time: 12:02:42 Freeze Frame: Voltage: 13.70 V 01869 - Rear Left Cold / Warm Air Outlet Motor Position Sensor (G351) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 47 Mileage: 271564 km Time Indication: 0 Date: 2002.09.13 Time: 00:04:32 Freeze Frame: Voltage: 14.10 V (no units): 140.0 (no units): 255.0 00727 - Potentiometer in Positioning Motor for Defrost Flap (G135) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 113 Reset counter: 68 Mileage: 271566 km Time Indication: 0 Date: 2002.09.13 Time: 00:15:04 Freeze Frame: Voltage: 12.80 V (no units): 78.0 (no units): 255.0 00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 32 Reset counter: 71 Mileage: 271568 km Time Indication: 0 Date: 2002.09.13 Time: 00:05:05 Freeze Frame: Voltage: 13.80 V (no units): 220.0 (no units): 255.0 00819 - High Pressure Sensor (G65) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 52 Reset counter: 74 Mileage: 271606 km Time Indication: 0 Date: 2002.09.13 Time: 01:03:36 00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 19 Reset counter: 47 Mileage: 271719 km Time Indication: 0 Date: 2002.09.13 Time: 02:41:52 Freeze Frame: Voltage: 14.00 V (no units): 241.0 (no units): 255.0 01868 - Rear Right Warm/Cold Flap Air Outlet Motor (V221) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 26 Reset counter: 71 Mileage: 271720 km Time Indication: 0 Date: 2002.09.13 Time: 00:05:44 Freeze Frame: Voltage: 14.10 V Temperature: 20.0°C (no units): 80.0 (no units): 82.0 Temperature: -87.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.clb Part No SW: 4E0 910 279 A HW: 4E0 907 279 A Component: ILM Fahrer H11 0060 Coding: 0011012 Shop #: WSC 80248 790 00005 VCID: 26150A78A4E7845793B-8072 Subsystem 1 - Part No: 4E1 910 113 Component: Wischer WWS D3 H30 0310 Coding: 00000030 Shop #: WSC 80248 3 Faults Found: 01496 - Bulb for Fog-Lamps; Left (L22) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 35 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:29:00 00458 - Control Module for Battery Monitoring (J367) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 74 Mileage: 275260 km Time Indication: 0 01500 - Bulb for Fog-Lamps; Right (L23) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 35 Mileage: 275556 km Time Indication: 0 Date: 2019.12.28 Time: 21:29:00 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 Component: Airbag 8.4E+ H08 0840 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 6393536C9755317FB45-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H08 0020 Coding: 0012141 Shop #: WSC 02311 785 00200 VCID: 65974D7499614F4F5A1-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H06 0050 5 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 6 Fault Frequency: 2 Reset counter: 74 Mileage: 271547 km Time Indication: 0 Date: 2002.12.15 Time: 15:53:30 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 2 Reset counter: 40 Time Indication: 0 Date: 2063.15.31 Time: 31:63:40 01336 - Company Data Bus for Comfort System 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 2 Fault Frequency: 2 Reset counter: 74 Time Indication: 0 Date: 2063.15.31 Time: 31:63:40 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 74 Time Indication: 0 Date: 2063.15.31 Time: 31:63:40 02071 - Local Databus 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 3 Fault Frequency: 4 Reset counter: 74 Mileage: 271548 km Time Indication: 0 Date: 2002.09.13 Time: 00:14:42 ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 900 E Component: KOMBIINSTR. VDO H33 0020 Revision: 5 992703 Serial number: AUDID3B9003509 Coding: 0000103 Shop #: WSC 80248 790 00005 VCID: 5CE16890AA2B0E87F5F-8008 1 Fault Found: 00562 - Sensor for Oil Level/Temperature (G266) 010 - Open or Short to Plus Freeze Frame: Fault Status: 00000011 Fault Priority: 7 Fault Frequency: 1 Reset counter: 14 Mileage: 271730 km Time Indication: 0 Date: 2002.09.13 Time: 00:02:34 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 HW: 4E0 265 081 Component: Heizgeraet H06 0280 Revision: 0000000E Serial number: 00000009001484 Shop #: WSC 00000 000 00000 VCID: 59EF7184A519FBAFEE9-800C 2 Faults Found: 02072 - Control Module for Energy Management (J644) 004 - No Signal/Communication 01406 - No Flame 000 - - ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4E0-910-468.clb Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H06 0070 Revision: 06 Serial number: 0000302A1609FC Coding: FDFE7FC62B3504 Shop #: WSC 80248 790 00005 VCID: 65974D7499614F4F5A1-8030 3 Faults Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 35 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 00:36:35 01207 - Control Module for Auxiliary Heater (J364) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 36 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 00:54:32 01517 - Control Module for Trailer/Towing Sensor (J345) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 7 Reset counter: 50 Mileage: 273763 km Time Indication: 0 Date: 2019.11.24 Time: 19:07:15 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 Component: CD-Changer H43 0470 Serial number: AUZ5ZBC1011215 Shop #: WSC 00000 000 00000 VCID: 1C612890EAAB4E8735F-8048 2 Faults Found: 02261 - Data Medium 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 7 Fault Frequency: 58 Reset counter: 72 Mileage: 275250 km Time Indication: 0 Date: 2019.12.22 Time: 15:26:23 Freeze Frame: Text: 0000EB11 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 74 Mileage: 275260 km Time Indication: 0 Date: 2019.12.28 Time: 08:04:44 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H01 0070 Revision: 00702901 Serial number: AUX3Z0B9102748 Coding: 0262144 Shop #: WSC 02311 785 00200 VCID: 58E97480DE13E2A7D17-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 1 Fault Found: 00668 - Supply Voltage Terminal 30 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 0 Reset counter: 74 Mileage: 275248 km Time Indication: 0 Date: 2019.12.26 Time: 05:17:56 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 A Component: KLIMA-STG. FOND 011 0100 Revision: 00000040 Serial number: 00000000001645! Shop #: WSC 00000 000 00000 VCID: 619F59648D49236FA69-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.clb Part No SW: 4E0 910 553 C HW: 4E0 907 553 C Component: LUFTFDR.-CDC H03 4190 Coding: 0015500 Shop #: WSC 00046 000 00000 VCID: 2313136CD7D5717FF45-8076 5 Faults Found: 01437 - Control Position not Learned 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 11100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 227 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 01:41:46 00776 - Level Control System Sensor; Left Front (G78) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 11101100 Fault Priority: 3 Fault Frequency: 15 Reset counter: 35 Mileage: 0 km Time Indication: 0 00778 - Steering Angle Sensor (G85) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 24 Reset counter: 51 Mileage: 271548 km Time Indication: 0 Date: 2002.09.13 Time: 00:00:07 01316 - ABS Control Module 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 8 Reset counter: 56 Mileage: 271551 km Time Indication: 0 Date: 2002.09.13 Time: 00:20:48 01598 - Drive Battery Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H41 1060 Revision: 00000000 Serial number: 305JL027508720 Shop #: WSC 02313 785 00200 VCID: 3B23CB0C4F6529BFDC5-806E 4 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 74 Mileage: 275260 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:47 Freeze Frame: Hex Value: 0x5E07 Hex Value: 0x0C63 Hex Value: 0x0048 02261 - Data Medium 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 7 Fault Frequency: 255 Reset counter: 35 Mileage: 271544 km Time Indication: 0 Date: 2002.09.14 Time: 11:51:01 Freeze Frame: Hex Value: 0x5E07 Hex Value: 0xC901 Hex Value: 0x0000 Hex Value: 0x0010 03183 - Data Media not Compatible 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 255 Reset counter: 75 Mileage: 271546 km Time Indication: 0 Date: 2002.10.10 Time: 20:05:29 Freeze Frame: Hex Value: 0x5E07 Hex Value: 0xC335 Hex Value: 0x0000 Hex Value: 0x0000 02927 - DVD Read Error 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 255 Reset counter: 35 Mileage: 271546 km Time Indication: 0 Date: 2002.10.29 Time: 09:55:28 Freeze Frame: Hex Value: 0x5E07 Hex Value: 0xC965 Hex Value: 0x0401 Hex Value: 0x0204 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H01 0090 Serial number: 00000331000171 Coding: 0003734 Shop #: WSC 28100 141 17409 VCID: 1D672594F1B1478FC21-8048 2 Faults Found: 01370 - Alarm triggered by Interior Monitoring 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 52 Mileage: 262136 km Time Indication: 0 Date: 2002.11.27 Time: 09:13:00 Freeze Frame: Bin. Bits: 10000000 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 2 Reset counter: 74 Mileage: 262136 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E1 959 801 Component: Türsteuer.FS BRM004 0060 Coding: 0002848 Shop #: WSC 80248 790 00005 VCID: 5EE56298BC371C979BB-800A 3 Faults Found: 00913 - Window Regulator Switch; Front Right Driver (E81) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 64 Mileage: 274512 km Time Indication: 0 Date: 2019.12.14 Time: 14:57:30 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 275248 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:42 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 275248 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:42 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H03 0030 Revision: 00300003 Serial number: W040310240183 Coding: 0000600 Shop #: WSC 28100 141 17409 VCID: 270B077CA3ED9D5FA8D-8072 Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H01 0020 5 Faults Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 35 Mileage: 245937 km Time Indication: 0 Date: 2015.12.07 Time: 08:50:12 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 74 Mileage: 275260 km Time Indication: 0 Date: 2019.12.28 Time: 08:04:45 00892 - Switch for Trunk Closing Cylinder (F248) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 48 Reset counter: 75 Mileage: 272150 km Time Indication: 0 Date: 2019.10.12 Time: 10:52:51 01501 - Bulb for Blinkers; Rear Left (M6) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 64 Mileage: 274563 km Time Indication: 0 Date: 2019.12.14 Time: 18:59:51 01504 - Bulb for License-Plate Light (X) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 119 Reset counter: 72 Mileage: 271546 km Time Indication: 0 Date: 2002.10.10 Time: 21:58:18 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H12 0460 Revision: PROD_01O Serial number: 00000000096737 Coding: 0000026 Shop #: WSC 02353 785 00200 VCID: 2A0DFE48B0FFA037B73-807E 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 74 Mileage: 275260 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:44 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000038207 Coding: 0010101 Shop #: WSC 22829 142 16354 VCID: 1E652298FCB75C97DBB-804A 3 Faults Found: 02072 - Control Module for Energy Management (J644) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 51 Mileage: 0 km Time Indication: 0 Date: 2023.06.06 Time: 00:00:00 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 74 Mileage: 262136 km Time Indication: 0 Date: 2019.12.28 Time: 08:04:00 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 74 Mileage: 262136 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E1 959 802 Component: Türsteuer.BF BRM004 0060 Coding: 0002848 Shop #: WSC 80248 790 00005 VCID: 5EE56298BC371C979BB-800A 4 Faults Found: 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 275248 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:42 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 275248 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:42 01482 - Motors for Central Locking 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 2 Fault Frequency: 14 Reset counter: 75 Mileage: 275536 km Time Indication: 0 Date: 2019.12.28 Time: 15:20:40 02115 - Locking Unit for Central Locking 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 14 Reset counter: 35 Mileage: 275552 km Time Indication: 0 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0000531 Shop #: WSC 80248 790 00005 VCID: 1F1B1F9CFBBD559FD0D-804A No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: AFS 1.Stufe H01 0020 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 80248 790 00005 VCID: 629D5668884F3877BF3-8036 4 Faults Found: 01539 - Headlights Not Adjusted 005 - No or Incorrect Basic Setting / Adaptation - MIL ON Freeze Frame: Fault Status: 11100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 227 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 00:16:58 01310 - Level Control System Control Module (J197) 008 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 227 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 00:16:58 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 271560 km Time Indication: 0 Date: 2002.09.13 Time: 00:14:02 02234 - Right Headlight Power Output Stage (J668) 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 8 km Time Indication: 0 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 L Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 388AS067509324 Coding: 0000001 Shop #: WSC 31414 790 00001 VCID: 313FE9249D29D3EF769-8064 2 Faults Found: 00856 - Radio Antenna 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 36 Mileage: 272951 km Time Indication: 0 Date: 2019.11.06 Time: 09:58:50 00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 25 Reset counter: 24 Mileage: 271544 km Time Indication: 0 Date: 2002.09.14 Time: 20:24:58 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 E HW: 4E0 919 148 Component: R0078 TVhybridT 0470 Revision: R0H06000 Serial number: 76300800716502 Coding: 0000302 Shop #: WSC 31414 790 00001 VCID: 25170D74D9E18F4F9A1-8070 4 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 74 Mileage: 275260 km Time Indication: 0 Date: 2019.12.28 Time: 08:04:14 00863 - Antenna 1 for TV (R55) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 5 Fault Frequency: 3 Reset counter: 36 Mileage: 272925 km Time Indication: 0 Date: 2019.11.06 Time: 09:18:31 00864 - Antenna 2 for TV (R56) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 5 Fault Frequency: 52 Reset counter: 37 Mileage: 272920 km Time Indication: 0 Date: 2019.11.06 Time: 07:50:18 00866 - Antenna 4 for TV (R58) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 5 Fault Frequency: 14 Reset counter: 36 Mileage: 272921 km Time Indication: 0 Date: 2019.11.06 Time: 09:16:14 ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 B HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0240 Revision: 00000000 Serial number: 00000000002487 Shop #: WSC 22829 142 13099 VCID: 1F1B1F9CFBBD559FD0D-804A Subsystem 1 - Part No: 000 915 105 AK Component: von VA0 0404050245 Coding: 303030393135313035414B56413030343034303530323435 Shop #: WSC 80248 790 00005 5 Faults Found: 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 23 Reset counter: 255 Mileage: 271544 km Time Indication: 0 Date: 2002.09.13 Time: 01:47:32 02254 - Interface to Generator 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 75 Mileage: 271730 km Time Indication: 0 Date: 2002.09.13 Time: 00:01:21 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 18 Reset counter: 255 Mileage: 271546 km Time Indication: 0 Date: 2002.11.12 Time: 03:08:25 02256 - Quiescent Current 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 34 Mileage: 275260 km Time Indication: 0 Date: 2019.12.26 Time: 11:45:44 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 275264 km Time Indication: 0 Date: 2019.12.28 Time: 10:52:24 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM004 0060 Coding: 0003872 Shop #: WSC 02311 785 00200 VCID: 5DE76594B131078F821-8008 3 Faults Found: 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 275248 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:42 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 275248 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:42 02115 - Locking Unit for Central Locking 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 14 Reset counter: 35 Mileage: 275552 km Time Indication: 0 Date: 2019.12.28 Time: 16:41:42 ------------------------------------------------------------------------------- Address 69: Trailer Labels: None Part No HW: 4E VCID: 55F77DB4C901DFCFCA1-8000 Subsystem 1 - Part No: 4E0 Component: Shop #: WSC 65536 001 394790 2 Faults Found: 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication Freeze Frame: Fault Status: 00000000 Fault Priority: 0 Fault Frequency: 20 Reset counter: 82 Mileage: 158721 km Time Indication: 0 Date: 2000.00.20 Time: 00:16:02 Freeze Frame: Raw, Index/Key Err.: 252 000 000 Chan. Number: 130 Resistance: 9 ohms Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 00008 - Control Circuit for Left Fog Lamp 008 - Implausible Signal Freeze Frame: Fault Status: 00000000 Fault Priority: 0 Fault Frequency: 20 Reset counter: 82 Mileage: 158721 km Time Indication: 0 Date: 2000.00.20 Time: 00:16:02 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM004 0060 Coding: 0003872 Shop #: WSC 02311 785 00200 VCID: 5DE76594B131078F821-8008 4 Faults Found: 01482 - Motors for Central Locking 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 2 Fault Frequency: 14 Reset counter: 66 Mileage: 275008 km Time Indication: 0 Date: 2019.12.16 Time: 08:43:36 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 14 Reset counter: 40 Mileage: 275216 km Time Indication: 0 Date: 2019.12.19 Time: 07:17:30 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 275248 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:42 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 275248 km Time Indication: 0 Date: 2019.12.28 Time: 08:03:42 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 HW: 4E0 919 283 A Component: Parkhilfe 8-Kan H07 0030 Coding: 0011008 Shop #: WSC 02353 785 00200 VCID: 60995C6086432A67A97-8034 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End----(Elapsed Time: 02:21, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)----- Last edited by classexa; 7th January 2020 at 03:20 PM. |
I am new to D3 myself so not much experience yet but in general ABS pump should only be running when ABS/ESP/EDL is activated, not all the time. I don't think there are any external relays for ABS. Looks like your ABS unit is shorted causing pump to run all the time. I don't know if it has internal relay which could be stuck on or if it is activated with transistor which could be shorted. Pump running all the time could cause voltage drop in the unit especially if battery is weak and that could result in communication errors.
The first time I noticed the running pump after the car was shut off, was on NYE(Dec. 31). That was the first time. Haven't driven it since(well, I drove it home). I bought the car Dec. 27.
A8 D3 2003 4.2 Quattro Engine: BFM / Gearbox: GNU Last edited by classexa; 7th January 2020 at 03:28 PM. |
If you are resetting each time, and all those errors are coming back - I would focus on the low voltage ones as it shouldnt be flagging up voltage errors on a good battery.
If you don't have a good battery and stable voltage, all kinds of weird things can happen. if the battery is good, it might be a faulty or mis-calibrated power module.... You could try disconnecting the battery, charging it to full and then recoding the battery module to get things back in sync if it is definitely a good battery. I wouldn't waste time diagnosing anything else until the power is stable....
For parts enquiries and Forum User Administration please contact customer services directly, not me - enquiry@a8parts.co.uk, www.a8parts.co.uk, or call 01642 783537 The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black , 2007 TT Roadster, 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
