Speed Sensor or not??
Firstly, hope you are all safe in the current environment.
I have just come back from a 3 week trip which took over 7 weeks as I ended up stranded with no flights! Anyway, that's another story, now to the car... My car was standing and when I realised I was stuck abroad, I got a family member to charge it up (was flat) and put some fuel in/take it for a drive. Car was fine and behaved itself with no faults (surprisingly) although I know there would be some under-voltage faults stored. FF to present day and I started the car and moved it onto the driveway ready to be washed, parking brake on. After about 20 mins I realised I had to go get some meds so jumped in the car, started it and BOOM the ABS/ESP/Handbrake fault lights lit up. I drove it around the block, no change. I then cleared all the codes but the ABS one won't go away. It shoes as N/S/R speed sensor intermittent signal but having read some threads I'm not sure if it actually is this or something else? Bit of a coincidence it's happened after standing for a while. I did do a scan but saved it after I cleared the codes (Doh!) and so will scan again tomorrow. Battery was charged again fully but fault persists. Fuses all checked on both sides of the dash, no problems. Any more pointers on what to check before I order a new sensor? Also, anyone know the OEM or should I just buy from TPS? My bonnet has also decided not to open but that will be tackled tomorrow fingers crossed.... Thanks
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder |
N/S is the left side, correct? If so, part number is 4E0927803D, superseded with F. O/S (right, in case I've got my sides wrong) is 4E0927804D, superseded with F.
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
What does the ABS fault say? Does the ABS work properly?
2006 Audi A8 3.0 TDI Quattro Sport A8 W12/S8 Brakes front and rear (385mm/335mm) Focal and JBL speakers, Helix amps S8 anti-roll bars front and rear Complete rear LED taillight Xenon fog lights All interior LED S8 rims 9x20" Stage II tune S8 Grill |
I'll rescan it today and post a log. Not sure how I can test the ABS
Without traffic around, brake hard and see/hear/feel if any wheel locks or not. If you are used to braking hard until the ABS gets activated, does it feel and behave the same way now? Be careful though.
OK it has now thrown a hissy fit! I went to read the codes and see what is showing.
Firstly, the car doesn't have a N/S/R speed sensor, from what I gathered it's front left and rear right. I checked the N/S/R wheel and can't see one either. With VCDS I tried to see what the ABS module is showing and it can't communicate with it now...and this has thrown up lots of faults. Parking brake, ABS and ESP were already there but now also headlamp, jacking light is on, level sensor, etc etc. My guess is that the ABS module is faulty and the car cannot determine lots of other data because of this and so it is throwing faults. These modules just show as DTC not supported or cannot read (or something to that effect). Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000731 Shop #: WSC 12982 000 1048576 VCID: 2019E2C9F6C1A42B732-8074 3 Faults Found: 01316 - ABS Control Module 008 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 3 Fault Frequency: 23 Reset counter: 26 Mileage: 158728 km Time Indication: 0 Date: 2020.04.15 Time: 14:33:38 Freeze Frame: Voltage: 10.04 V Count: 231 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 9 Mileage: 133232 km Time Indication: 0 Date: 2015.09.24 Time: 00:02:20 Freeze Frame: Voltage: 10.46 V Count: 61 01312 - Powertrain Data Bus 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 66 Mileage: 158728 km Time Indication: 0 Date: 2020.04.16 Time: 16:08:20 Freeze Frame: Voltage: 10.66 V Count: 20 Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 K HW: 4E0 614 517 BT Component: ESP 5.7 allrad H49 0650 Coding: 0001927 Shop #: WSC 02313 000 00000 VCID: 2B0305E58F077773D60-807E 1 Fault Found: 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 012 - Electrical Fault in Circuit Gateway Installation List: 4L0 910 468 A 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Cannot be reached 1100 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 6C-Back-up Cam. -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000
That's correct and yes the part numbers are the same as what I found on ETKA so thanks for the clarification. There is a new/old stock on ebay which I might purchase as it's cheap. Firstly though, I will get the old sensor off and give it a clean incase there is some dirt ingress due to it standing.
