Old 7th January 2021, 08:02 PM
S81 S81 is offline
Default Front upper suspension arms , d3 s8
Would anyone have the correct code for the front driver's side front upper control arm ,the rubber is damaged on the track rod and and I'm going to replace it as part of the winter maintenance,i've checked through posts and parts diagrams on net and the different versions and codes appear to be a mine field ,I contacted ecp as they have lemforder and trw listed but chap I know in there says although it's listed for s8 it's actual for the a8 and they don't do the ones for the s8 ,or if you had the correct lemfordor or trw part no and were to purchase that would be even better .
Thanks
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 8th January 2021, 09:57 AM
homer simpson's Avatar
Are we talking about 13 and 14?
Old 8th January 2021, 11:52 AM
Part numbers are dependent on VIN number with the S8. Details of both sets of top arms (left and right) are as follows:
VIN up to 4E-4-012 700*
Left front upper - 4E0407505E
Left rear upper - 4E0407509E
Right front upper - 4E0407506E *
Right rear upper - 4E0407510E
VIN past 4E-4-012 701*
Left front upper - 4E0407505F
Left rear upper - 4E0407509F
Right front upper - 4E0407506F *
Right rear upper - 4E0407510F
NOTE: The one marked with '*' is the one you specifically asked about, but just provided a list of both sets.
Old 8th January 2021, 05:36 PM
carmel120 carmel120 is offline
m&l in omagh have meyle ones they would be the oem equivalent just done mine today.
Try and loosen the pinch bolt sometimes they are a nightmare to get off.
Old 8th January 2021, 10:18 PM
S81 S81 is offline
Thanks chaps ,it's no 14 i need to change ,I was only going to replace it as rubber is damaged on the track rod end ,i'm assuming I don't need to change both at the same time ?
Daily driver
Previously owned
Old 8th January 2021, 10:24 PM
Shouldn't it be number 13 as 14 is the upper 'rear' arm?
Old 8th January 2021, 10:19 PM
Good point, and having gone through the process of removing a seized one, something I prefer to try and forget!
If required, part number for the bolt is N10576802 (M10x105x26) and costs about £4. The part number for the nut is N10272302 and costs about £2. If you plan on keeping the car, just replace them anyway.
