Old 2nd December 2023, 04:06 PM
danyalmakda danyalmakda is offline
Default Washer fluid pump
So replaced the washer pump from on off eBay but does not work still
There is no noise from the pump so is it just a cheap eBay version that does not work?
Is there a fuse anywhere for this washer pump or rely?
The wipers work for sure just not the washers
Headlight washers work fine
I’m assuming I should hear the pump working- I have no leaks as I replaced the grommets too
I’ve tried cleaning the nozzles too
I’m going with another faulty pump as no noise
2002 Audi A8 D2 3.7 Quattro AquaBlue
Old 2nd December 2023, 05:52 PM
Ronin Ronin is offline
there are 2 pumps.
Which one did you replace?
Old 2nd December 2023, 09:20 PM
The black one with the two grommets
Old 2nd December 2023, 09:53 PM
Absolutely. I got mine from eBay and it worked fine. Sounds like it's a dud. Can you check the connection and see if it's getting 12v when you activate the washer from inside?
Old 3rd December 2023, 09:46 AM
Have just put it back together
I have ordered an original used one- when that comes I will try check connection but not sure I have a voltmeter - just basic tools
Old 3rd December 2023, 09:47 AM
On the other note at least I stopped the leak with new grommets
