Old 11th October 2023, 11:21 AM
When I get round to fitting it are there any tricks, special tools, preparation/lubrication/calibration etc. required?
Start from page 66 of the following PDF:
Service Manual Electrical system 02 99.pdf
Old 11th October 2023, 01:15 PM
Thanks Sean, pretty much as expected. The torque settings are useful, though confusing.
(The wiper arm securing nuts are 20Nm or 16Nm depending which page you read!)
No comments about lubrication, if indeed any is appropriate?
Old 13th October 2023, 07:49 AM
donp38 donp38 is offline
Quite straight forward.
I have mine in and out a few times, trying to loosen mine up!
Old 21st October 2023, 05:09 PM
Take the right bonnet strut off and either prop the bonnet with a broom or have an assistant hold it for a few minutes while you pull the old one and fit the new one. Pull the motor forward, rotating around the centre spindle which is stuck behind the hvac inlet. When you get to about 45 degrees it'll pull out sideways.
Some lithium spray grease around the left linkage and in the rubber boots on the balljoints helps stop moisture getting in.
I think when I had your car in I put some additional boots on the top of the spindles to keep moisture out. Swap those over to the new one with some grease under them.
I'll buy the old one for parts if you are going to get rid of it.
Old 21st October 2023, 05:51 PM
Thanks MJ, I probably won't be doing it for a while now (problems at home) but the old one will DEFINITELY NOT be thrown away when I do! Your name will be on it.
