VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
A8 d3 odd scan
New to this stuff
Car came up a battery low And stopped mmi from booting Mmi only comes on and off again Changed battery and car runs fine but nothing working Coded battery and still the same Cleared codes and errors returned after a drive Saturday,12,November,2022,15:04:51:08597 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4 Data version: 20221026 DS344.0 www.Ross-Tech.com VIN: WAUZZZ4E84N015326 License Plate: Mileage: 115590km-71824mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 34 36 37 38 42 46 47 4F 52 53 56 57 5E 61 62 65 72 76 VIN: WAUZZZ4E84N015326 Mileage: 115590km-71824miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: Cannot be reached 1100 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: Cannot be reached 1100 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: Cannot be reached 1100 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Cannot be reached 1100 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: Cannot be reached 1100 57-TV Tuner -- Status: Cannot be reached 1100 5E-Ctrl Head LR -- Status: Cannot be reached 1100 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 1010 76-Park Assist -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 077-910-560-BFM.clb Part No SW: 4E0 910 560 Q HW: 4E0 907 560 Component: 4.2L V8/5V G 0030 Revision: 00000000 Serial number: AUX3Z0CN127976 Coding: 0011773 Shop #: WSC 00411 210 96661 VCID: 2F381B434B1F5523428-807A VINID: 9D196AAAA1152047800450C21865F1B97A 4 Faults Found: 17985 - Right Engine Mount Solenoid Valve (N145) P1577 - 004 - Open Circuit 17981 - Left Engine Mount Solenoid Valve (N144) P1573 - 004 - Open Circuit 18010 - Power Supply Terminal 30 P1602 - 002 - Voltage too Low - Intermittent 18061 - Please check DTC Memory of ABS Controller P1653 - 008 - - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 E HW: 09E 927 156 A Component: AG6 09E 4,2L5V RdW 0110 Revision: 00000001 Serial number: 0025352 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2412E46F12D9E67BAFA-8070 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 M Component: ESP 5.7 allrad H44 0500 Coding: 0008597 Shop #: WSC 02313 000 00000 VCID: 221EE27708CDE84BDD6-8076 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H03 0130 Revision: 01303703 Serial number: AUX3Z0CN127976 Coding: 0264192 Shop #: WSC 02311 785 00200 VCID: 58EA809F1E11729BF32-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H07 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 00000 785 00200 VCID: 2310E77317D7E143D60-8076 1 Fault Found: 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 191 Mileage: 114512 km Time Indication: 0 Date: 2003.02.27 Time: 03:52:35 ------------------------------------------------------------------------------- Address 07: Control Head Cannot be reached ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 016 0240 Revision: 00000022 Serial number: 00000000030648 Coding: 1069057 Shop #: WSC 02311 785 00200 VCID: 5AEE9A97601D608BC56-800E 4 Faults Found: 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 185 Mileage: 115594 km Time Indication: 0 Date: 2003.03.20 Time: 01:16:02 Freeze Frame: Temperature: 38.0°C 00819 - High Pressure Sensor (G65) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 1 Reset counter: 185 Mileage: 115581 km Time Indication: 0 Date: 2003.03.19 Time: 23:24:24 01858 - Air Outlet Sensor; Right Center (G348) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 189 Reset counter: 224 Mileage: 111614 km Time Indication: 0 Date: 2021.11.25 Time: 11:08:44 01857 - Air Outlet Sensor; Middle Left (G347) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 7 Reset counter: 224 Mileage: 115190 km Time Indication: 0 Date: 2003.05.22 Time: 01:51:50 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.clb Part No SW: 4E0 910 279 E HW: 4E0 907 279 E Component: ILM Fahrer H11 0100 Coding: 0000001 Shop #: WSC 02311 785 00200 VCID: 2A0E0A5770FD300B956-807E Subsystem 1 - Part No: 4E2 910 113 Component: Wischer WWS D3 H30 0320 Coding: 00000030 Shop #: WSC 02311 2 Faults Found: 00908 - Control Module for Wiper Motor 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 206 Mileage: 115191 km Time Indication: 0 Date: 2003.06.20 Time: 23:08:25 02510 - Steering Column Adjustment 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 254 Reset counter: 78 Mileage: 22878 km Time Indication: 0 Date: 2009.05.01 Time: 09:37:15 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 G Component: Airbag 8.4E+ H10 0940 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 6390A7735757A143960-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: 6594B96B5963DF73784-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H03 0070 1 Fault Found: 00886 - Turn Signal Switch (E2) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 215 Mileage: 114626 km Time Indication: 0 Date: 2003.03.25 Time: 13:08:02 ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 950 CX Component: KOMBIINSTR. VDO H42 0070 Revision: D08 Serial number: AUDID3C6000184 Coding: 0016403 Shop #: WSC 00411 210 175099 VCID: 5CE29C8F6A299EBBD7A-8008 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4E0-910-468.clb Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H07 0070 Revision: 07 Serial number: 1400303A0625E4 Coding: FCFE5BDD2B2505 Shop #: WSC 00976 210 82602 VCID: 6594B96B5963DF73784-8030 3 Faults Found: 00470 - Company Comfort Databus in Single Wire 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 13 Reset counter: 217 Mileage: 113937 km Time Indication: 0 Date: 2022.06.13 Time: 16:33:31 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 193 Mileage: 114605 km Time Indication: 0 Date: 2003.03.11 Time: 02:11:43 00384 - Optical Databus 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 254 Reset counter: 185 Mileage: 115190 km Time Indication: 0 Date: 2003.05.15 Time: 02:23:45 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Cannot be reached ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H03 0130 Revision: 01303703 Serial number: AUX3Z0CN127976 Coding: 0264192 Shop #: WSC 02311 785 00200 VCID: 58EA809F1E11729BF32-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.clb Part No SW: 4E0 910 553 E HW: 4E0 907 553 E Component: LUFTFDR.-CDC H05 4290 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2514F96B19E31F73B84-8070 4 Faults Found: 00778 - Steering Angle Sensor (G85) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 5 Reset counter: 215 Mileage: 114500 km Time Indication: 0 Date: 2003.02.27 Time: 00:36:47 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 103 Reset counter: 225 Mileage: 113783 km Time Indication: 0 Date: 2022.05.25 Time: 10:59:14 01577 - Turn-Off due to Over-Temp 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 4 Fault Frequency: 2 Reset counter: 203 Mileage: 114821 km Time Indication: 0 Date: 2003.03.29 Time: 05:21:47 01316 - ABS Control Module 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 206 Mileage: 115191 km Time Indication: 0 Date: 2003.06.20 Time: 23:08:27 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H07 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063330 Shop #: WSC 00000 785 00200 VCID: 2310E77317D7E143D60-8076 1 Fault Found: 00668 - Supply Voltage Terminal 30 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 225 Mileage: 115572 km Time Indication: 0 Date: 2003.03.19 Time: 04:39:56 ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H01 0090 Serial number: 00000331300033 Coding: 0035840 Shop #: WSC 02313 785 00200 VCID: 1D64D18B31B3D7B3E04-8048 1 Fault Found: 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 193 Mileage: 114604 km Time Indication: 0 Date: 2003.03.11 Time: 02:11:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E2 959 802 Component: Türsteuer.FS BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5EE696877C358CABB9E-800A 1 Fault Found: 00913 - Window Regulator Switch; Front Right Driver (E81) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 191 Mileage: 114512 km Time Indication: 0 Date: 2003.03.01 Time: 01:19:22 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H03 0030 Revision: 00300003 Serial number: W040311180041 Coding: 0000217 Shop #: WSC 02311 785 00200 VCID: 2708F36363EF0D638A8-8072 Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H02 0020 4 Faults Found: 01504 - Bulb for License-Plate Light (X) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 193 Mileage: 114499 km Time Indication: 0 Date: 2022.06.20 Time: 13:39:19 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 185 Mileage: 68437 km Time Indication: 0 Date: 2013.03.03 Time: 14:23:29 01308 - Control Module for Roof Electronics (J528) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 193 Mileage: 114608 km Time Indication: 0 Date: 2003.03.11 Time: 02:27:50 00892 - Switch for Trunk Closing Cylinder (F248) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 8 Reset counter: 225 Mileage: 115379 km Time Indication: 0 Date: 2003.06.27 Time: 23:58:12 ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H08 0020 Revision: Serial number: 00000000027974 Coding: 0010101 Shop #: WSC 02311 785 00200 VCID: 1E66D6873CB5CCABF9E-804A 1 Fault Found: 01797 - Power Steering Hydraulic Pressure Valve (N119/N315) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 254 Reset counter: 225 Mileage: 111100 km Time Indication: 0 Date: 2021.10.19 Time: 13:58:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E2 959 801 Component: Türsteuer.BF BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5EE696877C358CABB9E-800A No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 HW: 4E0 907 801 Component: EPB A01H019 H01 0190 Coding: 0000531 Shop #: WSC 00022 210 75084 VCID: 5CE29C8F6A299EBBD7A-8008 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01110000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 130 Time Indication: 0 Freeze Frame: Voltage: 12.01 V Count: 61 ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 57: TV Tuner Cannot be reached ------------------------------------------------------------------------------- Address 5E: Ctrl Head LR Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 A HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0230 Revision: 00000000 Serial number: 00000005308435 Shop #: WSC 00976 210 82602 VCID: 1E66D6873CB5CCABF9E-804A Subsystem 1 - Part No: 000 915 105 AK Component: von JCB 1310310223 Coding: 303030393135313035414B4A434231333130333130323233 Shop #: WSC 12345 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5DE4918B713397B3A04-8008 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 HW: 4E0 907 273 Component: Reifendruck 2 H01 0210 Coding: 0252127 Shop #: WSC 00000 785 00200 VCID: 5F98AB837B3F85A3B28-800A 2 Faults Found: 01477 - System Switched Off 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 253 Reset counter: 185 Mileage: 111570 km Time Indication: 0 Date: 2021.11.20 Time: 14:43:56 Freeze Frame: Speed: 0.0 km/h Temperature: 12.0°C Error Code: 0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. 01521 - Sensor for Tire Pressure 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 164 Mileage: 38994 km Time Indication: 0 Date: 2011.02.22 Time: 15:57:33 Freeze Frame: Speed: 38.0 km/h Temperature: 9.0°C Error Code: 0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5DE4918B713397B3A04-8008 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 187 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H11 0010 Revision: --.--.-- Serial number: 00000332500058 Coding: 0001008 Shop #: WSC 02313 785 00200 VCID: 211CED7B0DCBF353C4C-8074 1 Fault Found: 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 72 Reset counter: 176 Mileage: 96733 km Time Indication: 0 Date: 2015.02.12 Time: 06:51:15 End----------(Elapsed Time: 01:43, VBatt start/end: 12.4V/12.4V)----------- Saturday,12,November,2022,15:31:34:08597 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4 Data version: 20221026 DS344.0 www.Ross-Tech.com VIN: WAUZZZ4E84N015326 License Plate: Mileage: 115590km-71824mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 25 34 36 37 38 42 46 47 4F 52 53 56 57 5E 61 62 65 72 76 VIN: WAUZZZ4E84N015326 Mileage: 115590km-71824miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Cannot be reached 1100 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: Cannot be reached 1100 0F-Digital Radio -- Status: Cannot be reached 1100 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: Cannot be reached 1100 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Cannot be reached 1100 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Cannot be reached 1100 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: Cannot be reached 1100 57-TV Tuner -- Status: Cannot be reached 1100 5E-Ctrl Head LR -- Status: Cannot be reached 1100 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 077-910-560-BFM.clb Part No SW: 4E0 910 560 Q HW: 4E0 907 560 Component: 4.2L V8/5V G 0030 Revision: 00000000 Serial number: AUX3Z0CN127976 Coding: 0011773 Shop #: WSC 00411 210 96661 VCID: 2F381B434B1F5523428-807A VINID: 9D196AAAA1152047800450C21865F1B97A No fault code found. Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 E HW: 09E 927 156 A Component: AG6 09E 4,2L5V RdW 0110 Revision: 00000001 Serial number: 0025352 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2412E46F12D9E67BAFA-8070 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 M Component: ESP 5.7 allrad H44 0500 Coding: 0008597 Shop #: WSC 02313 000 00000 VCID: 221EE27708CDE84BDD6-8076 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H03 0130 Revision: 01303703 Serial number: AUX3Z0CN127976 Coding: 0264192 Shop #: WSC 02311 785 00200 VCID: 58EA809F1E11729BF32-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H07 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 00000 785 00200 VCID: 2310E77317D7E143D60-8076 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Cannot be reached ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 016 0240 Revision: 00000022 Serial number: 00000000030648 Coding: 1069057 Shop #: WSC 02311 785 00200 VCID: 5AEE9A97601D608BC56-800E 4 Faults Found: 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 185 Mileage: 115594 km Time Indication: 0 Date: 2003.03.20 Time: 01:16:02 Freeze Frame: Temperature: 38.0°C 00819 - High Pressure Sensor (G65) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 1 Reset counter: 185 Mileage: 115581 km Time Indication: 0 Date: 2003.03.19 Time: 23:24:24 01858 - Air Outlet Sensor; Right Center (G348) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 189 Reset counter: 224 Mileage: 111614 km Time Indication: 0 Date: 2021.11.25 Time: 11:08:44 01857 - Air Outlet Sensor; Middle Left (G347) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 7 Reset counter: 224 Mileage: 115190 km Time Indication: 0 Date: 2003.05.22 Time: 01:51:50 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.clb Part No SW: 4E0 910 279 E HW: 4E0 907 279 E Component: ILM Fahrer H11 0100 Coding: 0000001 Shop #: WSC 02311 785 00200 VCID: 2A0E0A5770FD300B956-807E Subsystem 1 - Part No: 4E2 910 113 Component: Wischer WWS D3 H30 0320 Coding: 00000030 Shop #: WSC 02311 1 Fault Found: 02510 - Steering Column Adjustment 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 254 Reset counter: 78 Mileage: 22878 km Time Indication: 0 Date: 2009.05.01 Time: 09:37:15 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Cannot be reached ------------------------------------------------------------------------------- Address 0F: Digital Radio Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 G Component: Airbag 8.4E+ H10 0940 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 6390A7735757A143960-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: 6594B96B5963DF73784-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H03 0070 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 950 CX Component: KOMBIINSTR. VDO H42 0070 Revision: D08 Serial number: AUDID3C6000184 Coding: 0016403 Shop #: WSC 00411 210 175099 VCID: 5CE29C8F6A299EBBD7A-8008 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4E0-910-468.clb Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H07 0070 Revision: 07 Serial number: 1400303A0625E4 Coding: FCFE5BDD3B2D05 Shop #: WSC 00976 210 82602 VCID: 6594B96B5963DF73784-8030 No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Cannot be reached ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H03 0130 Revision: 01303703 Serial number: AUX3Z0CN127976 Coding: 0264192 Shop #: WSC 02311 785 00200 VCID: 58EA809F1E11729BF32-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.clb Part No SW: 4E0 910 553 E HW: 4E0 907 553 E Component: LUFTFDR.-CDC H05 4290 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2514F96B19E31F73B84-8070 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H07 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063330 Shop #: WSC 00000 785 00200 VCID: 2310E77317D7E143D60-8076 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H01 0090 Serial number: 00000331300033 Coding: 0035840 Shop #: WSC 02313 785 00200 VCID: 1D64D18B31B3D7B3E04-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E2 959 802 Component: Türsteuer.FS BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5EE696877C358CABB9E-800A 1 Fault Found: 00913 - Window Regulator Switch; Front Right Driver (E81) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 191 Mileage: 114512 km Time Indication: 0 Date: 2003.03.01 Time: 01:19:22 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H03 0030 Revision: 00300003 Serial number: W040311180041 Coding: 0000217 Shop #: WSC 02311 785 00200 VCID: 2708F36363EF0D638A8-8072 Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H02 0020 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 185 Mileage: 68437 km Time Indication: 0 Date: 2013.03.03 Time: 14:23:29 ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H08 0020 Revision: Serial number: 00000000027974 Coding: 0010101 Shop #: WSC 02311 785 00200 VCID: 1E66D6873CB5CCABF9E-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E2 959 801 Component: Türsteuer.BF BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5EE696877C358CABB9E-800A No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 HW: 4E0 907 801 Component: EPB A01H019 H01 0190 Coding: 0000531 Shop #: WSC 00022 210 75084 VCID: 5CE29C8F6A299EBBD7A-8008 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01110000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 130 Time Indication: 0 Freeze Frame: Voltage: 12.01 V Count: 61 ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 57: TV Tuner Cannot be reached ------------------------------------------------------------------------------- Address 5E: Ctrl Head LR Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 A HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0230 Revision: 00000000 Serial number: 00000005308435 Shop #: WSC 00976 210 82602 VCID: 1E66D6873CB5CCABF9E-804A Subsystem 1 - Part No: 000 915 105 AK Component: von JCB 1310310223 Coding: 303030393135313035414B4A434231333130333130323233 Shop #: WSC 12345 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5DE4918B713397B3A04-8008 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 HW: 4E0 907 273 Component: Reifendruck 2 H01 0210 Coding: 0252127 Shop #: WSC 00000 785 00200 VCID: 5F98AB837B3F85A3B28-800A 1 Fault Found: 01477 - System Switched Off 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 2 Reset counter: 185 Mileage: 115595 km Time Indication: 0 Date: 2003.03.20 Time: 02:31:25 Freeze Frame: Speed: 0.0 km/h Temperature: 14.0°C Error Code: 0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5DE4918B713397B3A04-8008 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 187 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H11 0010 Revision: --.--.-- Serial number: 00000332500058 Coding: 0001008 Shop #: WSC 02313 785 00200 VCID: 211CED7B0DCBF353C4C-8074 No fault code found. End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/12.3V)-----------
Audi A8 d3 4.2 petrol 2004 Blue |
Have you also checked the car for water ingress due to blocked drains, as this will cause no end of headaches? Anyway, here's what I can suggest:
Address 02: Odd that the summary shows a Malfunction yet detail says 'no fault code', so just ignore Address 07 / 0E / 0F / 1E / 37 / 47 / 56 / 57 / 5E - I suspect these are all connected. Check out the following video and see if these modules have a tick against them. You can watch the entire video or just from where I have it starting (module 13 in the video): https://youtu.be/txzhjGfTqqI?t=115 Address 08: Old date. Try clearing from within module Address 09: Old date. Try clearing from within module Address 42: Old date. Try clearing from within module Address 46: Common on all Audis. Alarm is knackered, usually by corroded battery Address 53: Check out the following thread: https://forums.ross-tech.com/index.php?threads/14402/ Address 65: Old date. Try clearing from within module. Error shows 'System switched off'. Go into MMI and check if disabled. If it is, try enabling again and see if error persists, although I wouldn't have thought disabling it would throw an error code. If the sensors are dead (internal batteries), maybe that's why it was disabled Address 72: Possible faulty motor, but could be wiring as error is intermittent. Check out the following thread: https://forums.ross-tech.com/index.php?threads/2009/ Also check this video where they strip the lock mechanism down and spray it with contact cleaner: https://youtu.be/HlYGjZbVkDg?t=419
2001 A8 D2 FL 3.7 Q - LPG Conversion, Engine: AKC, Gearbox:FBB, Colour:LY5X Aqua Blue pearl effect, Interior:WJ light beige/dark beige valcona leather with burr walnut inserts My DIY jobs - Replaced alarm horn, Replaced Coolant Temp sensor, Updated RNS-D firmware, Installed Reversing Camera and Digital TV, Dashcam Installation, Retrofitted Rear Blinds, Auto-Dimming Rear View Mirror, Chrome Boot Struts Sold! 2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights My DIY jobs - Fan Jet Windscreen Washers, Retrofitted Electric Side Blinds |
My immediate reaction (as noted by Sean/Steamship) is that actually you DIDN'T clear the codes successfully.
The global clear doesn't always work, so I ALWAYS clear codes module by module and go back to check. THEN after a clear(ish/er) scan go for a drive and scan again.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Thanks for the replys
Checked the boot and some water in the wheel well The boot lid had water in it I think its getting in through the boot panel Where the handle is Will get it resealed Also car has no sunroof carpet is dry inside Also date and time in the car is 2003
Audi A8 d3 4.2 petrol 2004 Blue Last edited by Garry1; 12th November 2022 at 06:46 PM. |
I'm confused by your signature
2004 4.2 S8? If it's a 2004, it's not an S8 with a 4.2 block Do you mean a 2004 D3 A8 4.2? |
Was a typo I never noticed this sorry Changed it now
1. Water in the boot lid is most likely a result of water ingress through the light clusters, as over time the seals perish and in some cases the outer lense covering also start to separate from the rest of the unit. 2. Two other possible sources of water ingress are due to blockages in the a/c drains either side of the transmission tunnel and also blocked drains in the plenum chamber. These have been discussed on the forum. 3. If that is the case, it makes sense to correct the date and time so that any errors generated will have the correct date/time, as it's essential to know when it happened. Also, three of the dates in the second scan are after 2003, so this just results in confusion as to what happened and when. My course of action would be as follows: . Sort out the date/time . Go through the process shown in the video to see if the group of modules (07 etc) are selected . Perform a scan . Go into each module that has thrown an error and attempt to clear the codes . Note down any module number that fails to clear the codes . Go for a drive . Rescan car . Post scan along with details of any modules that failed to clear codes as performed above
The date and time
I haven't got a clue how to change it as the buttons on the wheel or dash not working
Check out the following page on the Ross-Tech site on what to do with that test: https://www.ross-tech.com/vcds/tour/optical-bus.php If you need a fibre optic bridge loop, you can buy cheap ones from the likes of eBay for around a fiver, as the OEM ones are around £40. Here's a link to one such example: https://www.ebay.co.uk/itm/132847813657
