Old 24th October 2017, 06:34 PM
clubadria clubadria is offline
Default VCDS comfort Databus
Just bought used VCDS because I have a parking brake warning light just come on.
Seems I need a new motor.
The thing that worries me is a fault with the comfort Databus, I notice that a fault for TPMS but car doesn't have them fitted.
Its took me a while to program the towbar, so anything else is going to be a nightmare.
These faults have been stored since I bought the car, Any help on where to start with the ABS and comfort module would be appreciated.
David
Old 24th October 2017, 09:48 PM
I shared your scan results below.
I would say that the parking brake motor may be just a sticking brake caliper so worth while putting the brakes in service mode and checking them out.
Your TPMS is probably coding of module 7 and needs TPMS coded out.
ABS module im not too sure about,
see what happens once you have sorted rear brakes and cleared the faults.
Rear footwell heaters all do that eventually, ignore it.
The comfort databus is a weird one and not sure where you should start.
Code:
Tuesday,24,October,2017,15:58:45:56826
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WAUZZZ4E97N009698   License Plate: OV56XJJ
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0F 11 31 15 16 17 18 19 1D 1E 25 28
          34 36 37 38 42 46 47 4F 52 53 55 56 61 62 67 69 72 76 77
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 4E1 910 409 B    HW: 4E1 907 409 A
   Component: 4.2L V8TDI  G000AGMª0010
   Revision: --H02---    Serial number: AUX3Z0F8307693
   Coding: 0011773
   Shop #: WSC 66565 257 00032
   VCID: 2345CB91E208025EB7-8076
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E1 910 156 S    HW: 09E 927 156 B
   Component: AG6 09E 4,2 TDI RdW 0010
   Revision: --H01---    Serial number:        0094324
   Coding: 0000001
   Shop #: WSC 02313 785 00200
   VCID: 33653BD152E892DE47-8066
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H46 0510
   Coding: 0008557
   Shop #: WSC 00583 000 00000
   VCID: 224BCE95FD120B56BC-8076
1 Fault Found:
00003 - Control Module
            014 - Defective
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 K
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0F8307693
   Coding: 0412672
   Shop #: WSC 02311 785 00200
   VCID: 58BFAC7DEBCE918692-800C
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: ELV                 XXXX
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
   VCID: 2447C88DE7060566CE-8070
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 769 P    HW: 4E0 035 729
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 343I%067583895
   Coding: 0000002
   VCID: 397909F97084688E8D-806C
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH03 0040
   Subsystem 2 - Serial number: 00000000019894
   Subsystem 3 - Serial number: 0118.08.060000000100010011ÿ
   Subsystem 4 - Serial number: 010011ÿ
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 225429 km
                    Time Indication: 0
                    Date: 2017.10.24
                    Time: 15:54:32
Address 08: Auto HVAC        Labels: None
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000098451
   Coding: 1071355
   Shop #: WSC 54509 001 1048576
   VCID: 1C37F06DDF763DA676-8048
2 Faults Found:
00066 - Rear Right Footwell Heater (Z43)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 225039 km
                    Time Indication: 0
                    Date: 2017.10.15
                    Time: 17:34:13
             Freeze Frame:
                    Voltage: 14.10 V
00065 - Rear Left Footwell Heater (Z42)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 73
                    Mileage: 219699 km
                    Time Indication: 0
                    Date: 2017.08.05
                    Time: 09:46:52
             Freeze Frame:
                    Voltage: 11.60 V
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
   Component: ILM Fahrer      H15 0230
   Coding: 0123121
   VCID: 366302C5419A87F660-8062
   Subsystem 1 - Part No: 4E2 910 113 C
   Component: Wischer WWS D3  H60 0440
   Coding: 00000037
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00139548
   Shop #: WSC 02313
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276U7301813
   Coding: 0000001
1 Fault Found:
00856 - Radio Antenna
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 7
                    Fault Frequency: 10
                    Reset counter: 196
                    Mileage: 225405 km
                    Time Indication: 0
                    Date: 2017.10.24
                    Time: 14:04:14
             Freeze Frame:
                    Voltage: 14.60 V
Address 11: Engine II        Labels: Redir Fail!
   Component: 4.2L V8TDI  G000AGSª0010
   Revision: --H03---    Serial number: AUX3Z0F8307693
   Coding: 0011773
   Shop #: WSC 06402 210 01865
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H13 3710
   Revision: 91H13371    Serial number: 0037P0G02EH+
   Coding: 0431707
   VCID: 275DDF819630EE7EEB-8072
   Subsystem 1 - Serial number: 63328RB40198D537O
   Subsystem 2 - Serial number: 63428RB40198AECD3
   Subsystem 3 - Serial number: 63528RB40198AEF2$
   Subsystem 4 - Serial number: 63628RB40198AF37Y
   Subsystem 5 - Serial number: 63729RB401A1BBB9.
   Subsystem 6 - Serial number: 63829RB401A1B2EF
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H14 0040
   Coding: 0112141
   VCID: 65C19589ACBC3C6E19-8030
   Component: Lenkradmodul    H07 0090
Address 17: Instruments
Cannot be reached
Address 18: Aux. Heat        Labels: None
   Part No SW: 4E0 910 105 A    HW: 4E0 815 069 F
   Component: Heizgeraet      H07 0110
   Revision: 0000000C    Serial number: 00000009006406
   Coding: 0000001
   Shop #: WSC 00000 000 00000
   VCID: 1A3BF675D542439664-804E
Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
   Part No SW: 4E0 910 468 B    HW: 4E0 907 468 E
   Component: Gateway         H11 0090
   Revision: 11          Serial number: 20003069160050
   Coding: FDFFFFDE2B7904
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 196
                    Mileage: 225390 km
                    Time Indication: 0
                    Date: 2017.10.24
                    Time: 13:49:49
Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
   Part No SW: 4E0 910 218 A    HW: 4E2 905 218 B
   Component: FPI_1           H01 0020
   Revision: 01000102    Serial number: 18092006172847
   VCID: 1F4DC761CE6026BE93-804A
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8204411
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0412672
   Component: ELV                 XXXX
   XXXXXXXXXXX ELV                 XXXX
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4E0 910 158     HW: 4E0 919 158 C
   Component: KLIMA-STG. FOND 017 0230
   Revision: 00000019    Serial number: 00000000046406
   Coding: 0000000
   VCID: 61C98199B894504EE5-8034
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Coding: 0015510
   VCID: 2A5B26B58522D316F4-807E
Address 36: Seat Mem. Drvr        Labels: None
   Component: Sitzmemory FS  H02  0010
   Coding: 4063342
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
   Component: MNS ECE         H48 1060
   Revision: 00000000    Serial number: 364I.067596064
   Shop #: WSC 00378 210 15036
   VCID: 3B7513F17AB85A9E9F-806E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H05 0090
   Serial number: 00000625600045
   Coding: 0036068
   VCID: 1D31FD69C46C34AE81-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 D
   Component: Türsteuer.FS BRM005 0180
   Coding: 0028590
   VCID: 204FC49DF31E1946AA-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
   Component: Komfortgeraet   H07 0010
   Revision: 00100007    Serial number:  W040610070067
   Coding: 0004829
   Subsystem 1 - Part No: 4E0 907 719
   Component: Neigungssensor  H05 0020
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 R    HW: 4E0 035 223 G
   Component: DSP-High D3     H02 0120
   Revision: PROD_01     Serial number: 00000000005772
   Coding: 0000023
   VCID: 2C5720AD8FD6CD2606-8078
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000094579
   Coding: 0010101
   VCID: 1E33FA65C96A2FB698-804A
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 D
   Component: Türsteuer.BF BRM005 0180
   Coding: 0028590
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
   Component: EPB  A32C0220   H02 0220
   Revision: A32C0220
   Coding: 0001031
   Shop #: WSC 00583 210 82263
2 Faults Found:
02428 - Left Parking Brake Motor (V282) Clamping Force Not Reached
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11110000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 225408 km
                    Time Indication: 0
                    Date: 2017.10.24
                    Time: 14:27:39
             Freeze Frame:
                    Voltage: 13.66 V
                    Count: 14
02430 - Left Parking Brake Motor (V282) Resistance to Movement
            003 - Mechanical Failure - MIL ON
             Freeze Frame:
                    Fault Status: 11110011
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 192
                    Mileage: 225280 km
                    Time Indication: 0
                    Date: 2017.10.19
                    Time: 07:05:31
             Freeze Frame:
                    Voltage: 14.91 V
                    Count: 18
Address 55: Headlight Range        Labels: 4F0-910-357.lbl
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Component: AFS 1           H01 0020
   Coding: 0000018
   VCID: 2959D9B98024D80EFD-807C
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH02 0020
Address 56: Radio        Labels: 4E0-910-541.lbl
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 396J2067547493
   Coding: 0000001
   VCID: 316931D9A8F4A0CE35-8064
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000021493
   Shop #: WSC 00000 128 00289
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  2610110695
   Coding: 344530393135313035412056413032363130313130363935
   Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: Türsteuer.HL BRM005 0180
   Coding: 0028590
Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0630
   Revision: 00000000    Serial number: 00000610040157
   Shop #: WSC 12336 024 394758
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Component: Anhaenger     H12 0100
   Revision: 2A001001    Serial number: 00000374292764
   Coding: 0100000000000000
   VCID: 316931D968F4A0CE35-8064
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0028590
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08730626204566
   Coding: 0301008
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H16 1130
   Revision: 00000000    Serial number: 00000007587236
   Coding: 0010900
End-------------------------(Elapsed Time: 04:19)--------------------------
Old 25th October 2017, 12:50 AM
Did some checking of the 00470 error code, and quite a lot of the results I came across point to a possible fault in the wiring loom in the drivers door. Specifically, the possibility of cracked or broken wires in the area of the rubber boot between the car body and door. If you have the time, it might be worth investigating.
Old 25th October 2017, 07:32 AM
Thanks for your replies,
Just looked at a print out when I first bought the car long story, but it had the abs and comfort faults logged.
Will look into the door idea, I've never been in another A8, when you open the drivers door does the instrument cluster wake up ?
The other thing that doesn't work properly is the fingerprint, if that is not part of the problem then it will have to wait.
David
