Old 17th December 2018, 06:14 PM
Markiii Markiii is offline
Default Upgrading the D2 Audio
Its been a long time since I've owned a saloon and even longer since I've owned something thats quiet enough to benefit from a decent hifi install, so i'm thinking of a decent audio build.
I've started by reading the entire D2 ICE forum, but most of the links with what I wanted to know in the stickies are dead.
So would appreciate comments on what speakers we get as standard.
Car is a non Bose and as best I can determine without dismantling anything speakers are
Front Tweeters - up to 1.5" (Powered from the HU)
Front Woofers - no idea on size? (Powered from the HU)
Rear doors 4" door mids (Powered from the HU)
Tweeters near the door handle but no idea what size? (Powered from the HU)
Rear deck 6.5" coaxial or sub? (Powered by attached amps)
I know the front woofers sit in a bass wave enclosure, do the rear doors have similar or are they simply sitting in holes in the door?
thoughts appreciated
Old 19th December 2018, 05:43 PM
hunker7 hunker7 is offline
I'd like to know too. Have standard setup non-Bose and it's pretty bad. Been thinking of one of them under-seat subs but don't know how to connect one to standard Concert 1.
Another issue I'm experiencing is rear deck "subs" gotto be plugged in for rear speakers to work
Old 19th December 2018, 08:19 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Under seat active sub will take a line input from a speaker - just tap in to rear door speaker wires in the 'B' pillar and configure to accept line input.
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 20th December 2018, 03:01 PM
oh we can do better than an underseat sub
Old 20th December 2018, 03:02 PM
on a related note anyone have a link to removing the door panels?
Old 20th December 2018, 03:43 PM
Check out the 'Retrofitted Rear Blinds' in my signature below.
Old 20th December 2018, 04:54 PM
This is an interesting debate, but my thoughts (having taken the door apart for other reasons using Sean's guide) is where do you put anything?
It's all pretty tightly packed inside a D2, and the only "decent" sub I've seen described is MJ's which IIRC is in the boot and uses the ski hatch to emit sound into the cabin.
Plus if you take a door apart you WILL need at least some of the door card clips (they break) and I thought I read somewhere that they're NLA.
I've taken an "executive decision" having "upgraded" from a PF S8 with Bose to a non-Bose FL S8 to stick with OEM and enjoy the engine......
