Go Back   A8 Parts Forum > A8 D4 > D4 - Everything Else
D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out
Old 11th November 2016, 08:21 PM
Albert_Swafega Albert_Swafega is offline
Default Here we go again..........Heater Woes
Well, it's that time of year, and you expect the heater to work?
Nope, took a ride today, and the only heat was off the heated seats.
Took a scan, and found:
Address 08: Auto HVAC Labels: 4H0-820-043.clb
Control Module Part Number: 4H0 820 043 D HW: 4H0 820 043 D
Component and/or Version: Klima 3 Zonen H14 0061
Software Coding: 3621002800
Work Shop Code: WSC 02313 785 00200
ASAM Dataset: EV_AirCondiFront 001050 (AU64)
ROD: EV_AirCondiFront_AU64.rod
VCID: 21503B5361C9138A302EBB9-8075
1 Fault Found:
0378 - Coolant Circulation Pump
B10D0 04 [009] - Internal System Fault
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 217
Mileage: 175128 km
Date: 2016.11.11
Time: 21:03:57
Has anyone seen this before? is there a circulation pump just for the blowers? Where is it? Are they easy to change?
2011 A8 Executive 3.0 TDI Quattro
Old 11th November 2016, 08:35 PM
Joe2.0E Joe2.0E is offline
Not had an issue with heat but there has been issues with electric coolant pumps.
See D4 - Common Faults - Wiring Loom Issues.
Old 11th November 2016, 08:46 PM
Cheers Joe,
searched "0378 - Coolant Circulation Pump" to no avail.
strange...it was there all along?
Old 11th November 2016, 08:47 PM
Sounds depressingly similar to the Auxiliary Coolant Pump that afflicts D2s and I think D3s to a lesser extent.
Old 11th November 2016, 08:57 PM
Yes, I had this on my car - was repaired under warranty so no idea of cost - but I don't think it was a huge job! Good luck.
Old 11th November 2016, 09:01 PM
Take a look at this thread - maybe helpful
http://forum.a8parts.co.uk/showthread.php?t=11613
Old 11th November 2016, 09:17 PM
were the blowers cold too Paul?
Old 11th November 2016, 09:26 PM
Honestly I couldn't say - no so as I had noticed.
Old 12th November 2016, 02:46 PM
Thanks for pointing me to the other thread guys.
Took her for a spin today, warm air from blowers within 2 miles.
Then shortly after, all cool again.
So........i suspect from cold, heat builds up in the heater matrix and all is fine.
But.... as soon as the engine hits temp and the thermostat opens, i'm losing flow to the matrix, cos the pump is u/s, and all heat goes towards the radiator.
Fingers crossed, ordered the pump, i'll let you know how it goes.
Albert
Old 20th November 2016, 04:11 PM
Well, pump arrived this weekend, installed, all is good in the world again..
Idiots guide, with photo's attached, hopefully it'll help someone else as much as a8parts forum has helped me over the last few months.
Albert
File Type: zip 2011 Audi A8 4H 3.0 Quattro Coolant Pump.zip (2.31 MB, 2236 views)
