OK, so thats the next job then. Dismantle, clean and re-assemble. I THINK i can see what should be happening and the tumblers sticking could well be the issue. At the moment Ive left it full of WD40 and Ill see what happens tomorrow when I should also be getting a new battery under the warranty. |
I think I showed the process in Vera's WITW thread.
I've actually got both screws (4 of with matching coloured caps) and pads on the front so that the plate fits the curve fairly snugly all the way across. :p |
Ooh, can any bright person find the link to Vera’s lock post? I probably won’t live long enough to wade through all the WITW posts!
In this case the battery was very dead. It was an old battery incapable of holding a charge for long that I was trickle charging just to keep the car alive whilst i sorted out the battery warranty issue on the other one. It was away being tested by Yuasa.
What's in the workshop this week, Pelikanblau edition I suggest starting from the start as it makes great reading (again), but if you're impatient then click on the next link: Boot Lock |
Thanks Sean +++
And thanks Sean from me too. Looking at that Im now convinced that the issue is the same as Vera's.+++
PS, Can that section of the thread be extracted and posted as a "How to..." in the appropriate thread on repairs? It is a common problem. |
David, I've just created a new thread in the D2-Common Faults section with those instructions. The link to it is as follows: Boot Lock Failure - Removal and Repair I have also stated in that thread that it is MJs work. I don't want to take credit for it (as some people won't read the first part) and I'd prefer it if MJ had the final say on it's posting. |
