12th April 2016, 04:26 PM
Originally Posted by kungfupanda
Can you take the engine cover off to see whether the auxiliary belt drives the power steering pump? If it does, check if it's in good condition and not come off any of the pulleys?
Clutching at straws here but it's a simple check to do.
Not sure about the A8s, but I had the same problem a few years back on an A4 2.5 TDi. Could barely budge the steering wheel. Belts looked OK visually, but turned out to be one of the tensioners had gone.
