16th July 2016, 11:26 AM
Originally Posted by HPsauce
Thanks Sean, I'm also going to investigate doing it via modifying one of the numberplate lights as that camera is a similar size to the aperture they fit in.
Advantage would be not needing to butcher the mounting plate, disadvantage would be not central and not pointing straight back.
I had originally thought about getting one of the cameras that replaced the numberplate light, but gave it a miss. With the wide angle lens, I don't think you'll notice it being offset slightly... well, not compared to mine anyway, which is considerably offset.
