Old 23rd December 2016, 06:23 PM
I did have an issue with mine a year or so back, but don't recall the light sequence.
The car was up to temp and had switched over to LPG by the time I got onto the open road. When I got up to speed, it gave me the warning buzzer for no LPG and switched back to petrol. I tried switching back to LPG, but it reverted back less than 30 seconds later. It was due for the LPG service soon, so took it up early. Explained the issue to them, and they diagnosed it as a faulty coil pack. They said that the LPG is less tolerant to external issues, and so switches back to petrol.
Having just had work done on the engine, is there a possibility that one of the leads to a coil pack has been knocked. Either that or you now have a faulty coil pack.
Unfortunately I have no idea if you can use VCDS to test the coil packs, and the people who worked on mine said they spotted the fault with whatever software they use on the LPG system.
